Question about GE WBSR3140D Top Load Washer
Broken timer tabs
I have a GE WHDSR315 washing machine. In a fit of anger, I broke the tabs off of the timer mechanism. I took the timer dial off - opened the front panel and noted that the tabs that lock the timer to the front panel were broken. This meant that the stem of the timer pushed in and away from the front panel too far to engage. Rather than spending 80 to buy a new timer merely to get two new little pieces of plastic, I decided to glue the timer to the housing. Now, this was somewhat successful, now allowing me to use the inner ring to move the timer to different settings and thus use the washer. The problem is that I have lost the push in to start mechanism. The timer knob, when attached, seems to far out. Basically the timer seems stuck in the pulled out position. Any thoughts? Was there supposed to be more play than the glue now allows or is it something else related to the tabs?
  • 178 Answers
SOURCE: ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Posted on Mar 16, 2008
SOURCE: ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Posted on Dec 07, 2008
SOURCE: GE Washer timer malfunction
your white outer switch is stripped. i just had GE send me my 3rd one and it isnt 2 yrs old.( in april it will be). that is why you can move it with the outer ring.Good luck
Posted on Jan 21, 2009
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
SOURCE: The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
Posted on May 04, 2009
Why can't I hear the timer ticking?
The timer, if it's the mechanical type that you have to push in the knob to select cycles, then pull out to start, is *not* repairable. From what you are describing, it sounds like the internal mechanism had broken and the timer needs to be replaced. There is a specific, small procedure for removing the dial and replacing it on the new timer--if you are unsure on how to do this, get a qualified tech to do it--otherwise you run the real risk of breaking the mechanism in the new timer. I hope I helped you!
Aug 10, 2015 | GE Washing Machines
Kenmore front loader stops/freezes in pump out mode just before final spin
For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Aug 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
How do I align my Dial to my GE Washing Machine Timer
Most GE knobs and dials have either a flat spot or notch on the knob that aligns with a similar spot on the shaft. They can only go on one way.
Oct 20, 2014 | General Electric WH11X10033 Dial Assembly
The timer dial has to be pushed in manually to get it to engage the gears (really hard to do). Now when we pull it out, the water does not come on.
The timer knob and or the timer may need replacing here is a link for checking and replacing http://appliancehelponline.com/topwashertimervideo.html
The inner knob teeth tend to wear off on the ge top loaders, so check that first. You might have also broke the screw tabs that hold the timer in place from having to push it hard.
Aug 02, 2010 | GE WDSR2080D Top Load Washer
GE washer whdsr315 will not agitate, everything else OK How do I get at agitator
Pull off the softener cup
pull of the cap underneath
unscrew the bolt
pull up on top of agitator...it might need persuading
Nov 02, 2009 | GE WBSR3140D Top Load Washer
Timer control won't ingage. Took timer knob off and it seems to be ok but it will not ingage with the teeth on the part below it. It just goes around. Disk that has the pointer on it seems to fit properly...
A pin thru the timer shaft can break, or the plastic teeth it engages in can be stripped.
It is not difficult to repair if you have the parts, but you can only get these from another timer- maker will not supply parts.
To take timer apart.
Take it out of the machine.
You will see two twisted metal tabs on the back and one on the front.
Carefully straighten the tabs and the timer will come apart as FRONT, BACK, CAM ROTOR
Gently remove the shaft and you will see what part has failed.-- replace.
Be very careful with reassembly not to bend the contact fingers.
Sep 12, 2009 | GE Washing Machines
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Spin cycle will not engage, however the timer will continue and start the machine at the next wash cycle
open the lid when it starts spin cyce, use a small screw driver or whatever you have that's small enough to fit in the hole under the lid that the tab from the lid goes into. try pushing it in that's a saftey swicth that prevents the washer going into spin cycle with the lid open. it's mostly that
Aug 16, 2009 | GE Washing Machines
Door locked
To manually unlock the door lock system, perform the following steps. Power off the mains.
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Mar 19, 2009 | GE Washing Machines
Dishwasher not washing
sounds like the wash pump (wich recirculates the water during wash) has something stuck in the impelor or the wash pump motor is faulty. someone qualified would have to check this for you
Feb 18, 2008 | Dishwashers
GE WBSR3140D Top Load Washer Logo
109 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
