Hi there, my internet connection has been working fine up until yesterday, when i now try to connect, it says page cannot be displayed, you are not connected to the internet. Have unplugged netgear and plugged back in, but still the same, this is happenin on both PC and laptop??
Hi try to test your internet connection by using a a eithernet cable and directly pluging into you router and computer. If your connection works fine with that connection then try to reset your router back to factory settings and use a new password just in case someone has been bumming off your wifi. also contact your service provider to have them ping your system, they can test the connection from their end.
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
I have a different router with similar problem but to fix this problem I just shut down the CPU and the router, then I waited a minute or 2 so it would reset and when I turned it back on everything woked fine. could be as easy as clicking on the repair internet connection icon so it will rest IP, but you may have already tried that. Good luck
