Question about Hunter Low Profile III 20807 Ceiling Fan
Hunter ceiling fan
Can hear motor humming when on high, but blades turn very slowly. When you push blades, doesn't seem to be bound or hard to turn. Not sure about the exact model. Is a 5 blade fan with a globe light kit
    Genius:
  • 1,036 Answers
Motors work with magnets. These may be permanent, or more commonly elecromagnets. These are the rotor, and the field magnets. Another type of motor just uses a field magnet and iduces flux in the rotor.
Either way, it sounds like one of the main coil windings has either burnt out or mechanically broken.
If you want to remove it and test the coils with a meter (check resistance of each) this should show the fault.
If a coils burn't out. it's scrap .
Posted on Jun 11, 2008
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
A customer of mine has a very nice Hunter original ceiling fan that she never oiled and now the fan just hums and wont spin. Is it possible to repair after no oil damage is done?
Put some oil in and turn blades by hand to lubricate the bearings. If the motor is frozen, then you would have to take it to a service center or send back to Hunter for repair.
Apr 17, 2013 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
I bought two Beacon Hill Hunter ceiling fans recently. I bought them because of the promise of "whisper quiet." To my great disappointment the motors are loud. I have one on in another room...
It may not be the motors making the noise, but the blade irons that are attached to the motor are loose and are rubbing the housing.
To confirm this, turn the fans OFF. When the blades stop turning, use a step ladder to reach the fan blades and the blade irons. Using a Phillips head screw driver, attempt to tighten each blade iron screw (2 in each iron), that screws into the fan motor spindle. I suspect, you'll find one or more loose. Especially if, the lock washer wasn't installed on each screw.
Hope this helps you solve the problem. If it doesn't, contact Hunter per the instructions in your Owners Manual. As there is a slim chance that there is a manufacturer's defect involved.
May 06, 2011 | Hunter Heating & Cooling
Remote control works the light on my Hunter ceiling fan but blades do not move
Can you hear the motor run even though the blades are not turning? If so, the manifold/flywheel may be bad and perhaps have broken away from the motor shaft.
Aug 28, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
When i turn on the fan i heer the moter but the
The motor just hums along without spinning means the armature has expanded from heat from running through the years. It is time to replace the fan or the motor if one is found at a decent price
Jun 10, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
Ceiling fan turns slowly
If you've had it for a few years, the bearings are probably getting bad (dry).
Always start a fan on high---then go to the speed you want, only the high speed windings will handle start-up.
Apr 26, 2009 | Dryers
Ceiling fan
There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
Hunter Low Profile III 20807 Ceiling Fan Logo
305 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
