Question about Carver Audio Players & Recorders
Carver M-400a schematic
I'm looking for a schematic of the Carver M-400a power amp  that's relatively affordable.  So far I found only one, and that costs $ 75.  Isn't there anything less expensive available, or maybe even a free download?
  • 4,234 Answers
You are not likely to find any Carver stuff for short money. What is the problem you are trying to solve? Maybe you don't need a schematic.
Posted on Jun 11, 2008
Where to find grounding point for amp on 05 equinox
Hello Joshua Wells,
Without buying, borrowing or begging a copy of
check out the wiring diagrams on the BBB INDUSTRIES
site (see below: registration required).
& WIRING Diagrams
... (nice).
Another excellent source for sound, communications, navigation, video parking... hoo-haw (et al)... is CRUTCHFIELD.
They have all the related fitment hardware... electrical (plug) interface and EXPERTISE to afford you the optimally PROFESSIONAL GRADE installation.. that can give your years of reliable service... and sell on with confidence...
Free queries entertained... (live or chat).
(very cool).
Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
BBB Industries Premium Alternators Starters Power Steering Products
Nov 12, 2016 | Cars & Trucks
Is it normal for carver power amps to have a slight hum? I have a carver-55x
Hum can come from a jillion different places. Is this hum coming from the unit with no speakers connected, or is it heard through the speakers? What sources are being used? What cables? Are thereany common sources of interference near? Troubleshooting is difficult without much information.
Jan 11, 2015 | Carver Audio Players & Recorders
My Carver M-1.5t is emitting a rapid pulsing sound on both speakers -- low but annoying. I bought it new in around 1983. Is it fixable?
this could be related to the power supply it is the
magnetic field variety that has a thyristor controlling its input check if the voltage supply to the amp outputs is varying when the pulsing is heard. if so
the control curcuit could be at fault.
Apr 25, 2010 | Carver PM950 Amplifier
Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Feb 23, 2010 | Audio Players & Recorders
RE: arver Sunfire Super Junior subwoofer. In attempting repair, I found Q12 shorted, gate to source(not to drain!), and F1 open. After replacing with exact cmpnts, operation returned to normal, however,...
is that resistor in the line to q12 ? if so it should be in the spec sheet for that device. if you don't have the spec sheet then let me know what q12 part number is.
Nov 12, 2009 | Audio Players & Recorders
I have a carver M 1.5 amp rt. channel is out.
Carver designs in general are not easy to repair. I would recommend that you send this unit into a Carver authorized service center. The likely problem is the output transistors, but the driver circuits and predrivers are not simple designs and if there is a problem there, it could effect the outputs. Tracing this will require equipment and schematics that I don't believe are available on the net.
Sep 04, 2009 | Carver PM950 Amplifier
Best amps for bose 901
You need an amplifier with at least 200 wpc to get the most out of your BOSE. Look into getting a NAD, ADCOM or CARVER amplifier. I prefer CARVER myself. I am running a CARVER M-500T(251 wpc) on my 901's and they sound incredible.
Aug 25, 2009 | Bose 901 VI Main / Stereo Speaker
Carver PM900 power amp with hum/buzz
1-shut down all flourecent lamp and check.
2-check for your cables in a good condition and no touching of wires to the body of amp.
3-connect(ground loop isolator)code number(270-054)from radio shack near you and connect it between your audio device(like cd player and amp)
Apr 15, 2009 | Audio Players & Recorders
Carver Sound Problems
your going to need this place to download the remedy's for your system
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Carver tfm-35x power amp light replacement
I just picked up the same amp, a Carver TFM-35x, with the same problem, the bulbs that light up the meters are burnt out. They aren't hard to replace, but I didn't know what bulb to use. I found out today that you need to use 12 volt, .15 amp bulbs (150 milliamp). And it needs to be an axial-type bulb.
Jun 21, 2008 | Audio Players & Recorders
316 people viewed this question
Top Carver Audio Players & Recorders Experts
Are you a Carver Audio Player and Recorder Expert? Answer questions, earn points and help others
