Question about Toshiba Satellite A135-S4527 Notebook
Blank Screen My computer screen is blank, but i can hear my computer running. Before the computer shut down a blurry blue screen appeared and stated my computer may need updating. Since it shut down, it has not turned back on. I would have put in a recovery disc, but the cd drive will not open. Does this have anything to due to my monitor, battery, bulb, or dust??
    Genius:
  • 2,028 Answers
Sound like you have a major problem, but try this.
There is a small hole in the front of your CD drive. Staighten a paper clip and stick it in the hole, it will open.Then try plugging into an external monitor and using your recovery disc.
Posted on Jun 11, 2008
  • 70 Answers
If you can hear your windows loading but no display, try plug-in an external Monitory on your Laptop. If you can see the display on the screen with this monitor then maybe your LCD or Inverter is broken, or try turning on/off the switch for External Monitor and LCD Display on your keyboard. Usually by holding the "FN" key on your keyboard and look for the LCD/VGA icon on your keys then press it.
-mrsolution
Blank screen
Check keyboard for 'F' keys which relate to screen Functions. Look for brightness UP or DOWN keys and if nothing else works hold down POWER button until it shuts down. Then push button and allow it to start up again. It will run through self-diagnostic testing and will ask if you want to run computer in Safe or Other Modes-pick Normal Mode.
Very often this will fix the problem.
Sep 15, 2012 | Packard Bell NX.BWTEK.002 EasyNote TS 15.6...
HP touchsmart 310 Screen goes blank after turning on and stay's that way.
You best bet is to pull the hard drive and attach it to another computer. This will allow you to copy the infomation you are worried about to another sorce. Most computer retailers that offer services will have a back up service and can do this for you. The average cost in my area for a back is $100.
Once you have the computer repaired, make sure you back things up. If you are worried about loosing something back it up twice. External hard drives are reasonably priced, and most computer have some kind of optical burner.
Hope this helps
Jun 27, 2012 | HP Computers & Internet
Dell Latitude D830 running Windows 7. Also running laptop screen plus additional monitor. I was watching a visor from cnbc.com when the addt'l monitor went blank and the laptop screen went a broken...
Hallo there
I hope you have got your screen beack, if not try to restart your computer in safe mode.
The restarting can be done in the following way:
1. Click START, click TURN OFF COMPUTER, and then click RESTART
2. While the computer is starting, press and hold down the F8 key until the Startup Menu appears
3 Use the UP ARROW and DOWN ARROW to select Safe Mode, press ENTER.
Now to the display settings
1 Open Display Properties in Control Panel
2 Click the Settings tab
3 If for some reason you are not in safe mode go through following:
In Colour quality, clock to alower settiing
Move Screen Resolution slider to the left if you want to reducethe size of the desktop
To Refresh frequency click Advanced and check the Adapter and Monitor.
4 After you have made your changes click OK
restart the computer if you are told to do so. But do not do it in safe mode..
Good luck
Kobrun
Feb 29, 2012 | Dell Computers & Internet
Acer Extensa 4630. The screen is blank but the computer is running. The acer screen appears upon start up but then the screen turns black. Any suggestions?
have you enabled "standby"mode,you usually have an option when shutting down.Either this or go into settings and make sure you havent adjusted sleep mode for the screen
Sep 10, 2010 | Acer Extensa 4620 Notebook
Beeps half-dozen times then shuts down.
try ur windows disk,,put it in and go from there,,reformat if u have to,,or try sytem restore,,
May 17, 2009 | Dell Dimension 3100 PC Desktop
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Dec 05, 2007 | GPS
Blank screen
I think your LCD is stuffed is it under warranty do you know BUT if the screen is cracked they wont replace it typical HP. To get your external monitor running hold down the function key and the blue monitor looking key similtaneously normally on compaq its the F4 key but look around your keyboard (looks like a monitor) and is blue letters.
Sep 18, 2007 | HP Compaq Presario V2000 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
129 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
