Hi I have a 42" LG plasma is is 4 years old and has started showing an over cast green hue over the whole screen, this happens on AV1 AV3 and RGB-PC input it can last for hours or just a short time and then the colour balance is back to normal Help Tony.
    Problem Solver:
  • 5 Answers
Loose cables or the inverter thats my guess
Posted on Jun 11, 2008
I was av1, av2 before but now i can't access my lg 42'' flat screen A2
Hi happy,
This happens quite often due to current leakage from signal box.. Please continue with AV1. But Have your cable box or whatever signal box you are using for any current leakage so that AV1 remains safe. If you lose AV1 too, you may have to replace the main board.
May 07, 2015 | LG Televison & Video
How do i reset av and tv chanel on Samsung Series 4 PS42C430 42
i activate av1,av3 and av3 in service. my tv come on and off. i can't inter in service. samsung 42, PS42C430, SO HELP ME HOW TO DEACTIVE AND INTER IN SERVICE.
Jun 19, 2012 | Samsung PS42C430 42 Plasma TV
My LG 42pc1DV has sound normal but picture just died and is blacl, before this happened I had a lot of green pixels that only showed up across screen on dark pictures, 4 year old and just out of warrenty
Either your Y sustain board went out or your upper and lower Y buffer boards went out. Worst case scenario is your panel went out. But you won't know without replacing the other boards first.
Apr 10, 2012 | LG 42PC3D 42 in. Plasma Television
I have a 42 inch panasonic viera th-p42g10a. i have dvd connected to av1, foxtel to av2, av3 is vacant. I have lost volume to both dvd and foxtel connections, yet i still have volume when watching normal...
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Mar 03, 2011 | Panasonic VIERA TH-42PX80E 42 in. Plasma...
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma screen color problems
Hi
I just bought a 42pc5d plasma tv it's an LG I bought it in Sept. 07 it started doing the exact same thing your talking about here the red glow type thing. Luckily for me and I hope in your case that the tv is under warranty, although if you know someone or even a repair place I don't think it would cost much to fix (just a guess but the guy told me that it was an easy fix so don't let them try to screw you). It really is a simple fix according to the tech. You need to adjust the voltage. He took the tv and watched it until he saw the red and adjusted the voltage and I had my tv back the next day. This was about a week ago and I haven't seen it since. I hope this helps and I hope you have a warranty. By the way LG comes with a 2 year manufacturer's warranty standard so if you didn't get an extended warranty from where you bought it if it's less than 2 years old call LG and they will arrange to have it fixed that's what I did. Here's the number 1-888-542-2623. Good luck.
Dec 27, 2007 | LG 42PC5D Television
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
My plasma tv picture is green
take off back panel and adjust the V12(A) adjuster wheel on the power board it adjust the gas flow to the screen is should light up your screen
Sep 30, 2007 | LG MZ-42PZ14 42 in. Plasma Television
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
