Question about Toshiba Satellite A60 Notebook
My toshiba i hava a toshiba laptop..while i was working on it i close it with out shuting it down. so then it just went black.. so i tried to restart it and i took out the battery but the screen would remain black .. how do i fix this???
  • duuuh Jun 15, 2008
    laptop screen will not work even though the power light is lit , I have tried removing the battery and holding the power button down for 20 secs but no success .
    Master:
  • 497 Answers
Did you try Last Known Good Configuration?
http://support.microsoft.com/kb/307852
try this if ur notebook shows a little sign of life....
or else
1. unplug the laptop
2.take out the battery
3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit)
4.put battery back in
5.plug in laptop
6.try to turn it on
All the best
Have a nice day!
tc
Posted on Jun 11, 2008
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Hi i have just got a new Pavilion DV7 only a few weeks old on boot/start up it starts then goes off several times before it starts to load windows the fan starts and the lights come on then goes off...
Run CHKDSK/F to check for errors. There may be an error on the hard drive.
Closing the lid when closing down, puts it in sleep mode and it will restart much easier but the error should be removed.
Jan 20, 2011 | HP Computers & Internet
I have a Toshiba Satellite U505 pc laptop that was working earlier today. I was in the middle of showing a video to a friend when it just shut down. I turned it on again and the Toshiba screen showed up...
If that was a video over the internet you may have downloaded a smart virus. ( ie/ tricks the computer in thinking it is safe ). Shut the computer down and restart it in safe mode. F8 or F11 while it is booting up, ( I could never remember! ). Close all residual tabs/web locations and all other programs. Go to the START icon and restart in normal mode. Me thinks that should do it for you.
ash
Sep 25, 2010 | Toshiba Satellite U505-S2940 Notebook
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite a215-s7437 will not boot at all - black screen
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
Mar 14, 2009 | Toshiba Satellite A215-S4747 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Startup display problem P100 PSPA3E
Hi, ok clearly for the symptom of what describes modal to his portable , I understand that the fault of his equipment comes from the card of video, which not this on board but it is separated, if the problem that he presents also happens for the VGA port and for the DVI port, this indicates that the problem that his equipment presents into in the system board.
Dec 06, 2008 | Toshiba Satellite P100 Notebook
Toshiba Satellite A60 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
