My PC is not turning on.
I have cleaned the ram,but still it is not turning on.after putting on the power button the processor fan is running and smps fan is also running.
When i removed the ram and turned on the pc it is not producing any beep sound.
please assist !!
my motherboard is of murcury,ram 512 ddr1,hdd 120gb,processor p-4
  • 70 Answers
Please re-set the CMOS battery for 2mins then power-on the computer, and see if you can get any beep sound.
Posted on Jun 11, 2008
System won't start, power retries every 1-2 seconds
Make sure your smps power supply of cpu is working fine.
Make sure motherboard is not ground with cabinet cover.
Pull cmos cell from motherboard for 10 minutes then put it into it's position.
reattach the RAM memory into slot also make sure ram is fine.
Clean dust from all parts.
Reattach processor and it's fan.
Reconnect pci card or vga card if any.Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 03, 2010 | Intel Motherboard
Dosen't boot
Open cpu cabinet.
Refix RAM memory.
Reattch ATX power connector from smps to motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings are defaults.
REmove pci cards from pci slot of motherbord then check.
Open processor fan and processor then refix both.
Make sure motherbord not ground with cabinet cover.
Then check if still problems then change ram .check RAM and motherbord separately .
Nov 21, 2009 | HP Computers & Internet
I have a problem with Intel D845GVSR Motherboard with 2.0 GHz processor. When I power the M/B, only the Motherboard LED is on, but no boot, no cpu fan running. No beep code also. I check the SMPS, RAM,...
Think this should be an issue with the power button, Remove the wires running from the power button to MB and try starting the system with shorting the 2 lead of the power button..
Mostly, it can be due to bad power supply or Ram
Rate this solution
Sep 26, 2009 | Intel D845GVSR Motherboard
Dimension 8250 will not turn on but on button
open cpu cabinet
Refix RAM memory then check.
Pull cmos cell for 10 minutes frommotherbord so all settings defaults.
Also clean dust from all circuit.
Reconnect ATX connector from smps supply to motherbord.
Refix processor fan and processor.
Let me know if you need more assistanse.
Aug 31, 2009 | Dell Dimension 8250 PC Desktop
When I turn on my dell the processor fan comes on at high speed, but will not boot.The computer booted the night before and had no problems. I aam using a friends computer to send this problem.
First pull cmos cell from motherbord for 10 minutes so all settings defaults.
Then pull RAM memory clean dust from all circuits Put RAM in its position.
Then check .
If still same issue then reconnect ATX power connector from smps power supply to motherbord.
Dis connect harddisk connection and then check .
If you get display then connect harddisk connection again.
Then also open processor fan and processor then fix both again.
Then power up press F1 or F2 or "del" to enter in bios .
Then check in bios harddiks is detected or not?
Aug 31, 2009 | Computers & Internet
Power turns off after a few seconds
Open your case, power up and then look at the CPU fan. If it spins normally, you may go to bios set up, look for Hardware Control, go to the fan subject and disable the function of watching CPU temperature or put it at the highest rank. If it does not help, you may think of RAM problem.
Aug 11, 2009 | Computers & Internet
Nothing happens when I press the power button. No
What about the power supply? I bet it's supply's issue. Otherwise make sure that PWR button wires are connected properly and to the correct terminals of the motherboard
Jun 29, 2009 | Intel D915GAG Socket 775 Motherboard -...
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
