Foxconn P4M800P7MA-RS2 Motherboard Logo
Posted on Jun 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble with the date
Loss the time
any time i off my computer, it lost the date and time, it go to the begining
Karl Whisenand
Level 3:
Genius:
  • Master 1,554 Answers
  • Posted on Jun 11, 2008
Karl Whisenand
Master
Level 3:
Genius:
Answers
1554
Questions
Helped
753222
Points
4266
Look on the board and you will see a coin size battery to replace.
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
tip
Restore Windows XP to Previous Working State
You can recover the windows critical components and return your computer to earlier state without loss of personal data using windows XP built-in system restore feature. With new programs being installed, viruses infecting and spy ware creates problem in your browsers it is not unusual for your computer to suddenly stop behaving correctly. So you can perform the windows recovery process and return your computer to earlier state within a minute.
Follow the given steps to run System Restore wizard:
To use this feature, you will need to be logged into your computer with administrative rights:
  • First click on Start button.
    >>All programs.
    >>Accessories.
    >>System Tools.
    >>Then click on System Restore.
Now a "Welcome to System Restore" wizard will start, first read the detail instruction on left side of the page.
On right side of the page, click on "Restore my computer to an earlier time" check box under "To begin, select the task that you want to perform" area and then click on Next button
On the "Select a Restore Point" page, click on bold date option, but try to use a restore date as close as possible to a time just before the problem started then click on Next button
Now a next page will appear with title "Confirm Restore Point Selection", to restore your computer to this date and time then click on Next button to start the restore process.
Now system restore process recover the previous windows settings and your computer
will restart with "Restoration Complete" message, click Ok button to finish the process.
How to set time day date on my timex indiglo cr2016 watch
To set the time and date on your Timex Indiglo watch with a CR2016 battery, follow these steps:
  1. Press and hold the stem (the button on the side of the watch) until the display begins to flash.
  2. Use the stem to cycle through the different settings: time, day, date, and year.
  3. When you reach the setting you want to change, use the stem to adjust the value.
  4. Once you have set the time, day, date, and year to the correct values, press the stem to exit the setting mode.
If you have trouble setting the time and date on your watch, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Timex customer service for assistance.
We have a Panasonic UF - 770 fax machine which is showing the wrong time/date. Our manual has 'gone missing' so we're at a loss. Please can you help?
Oh thats an old beast. usually when the date and time go wrong it means it has lost all its memory and requires what is called a "shipment set".
To do this you press function,7,monitor 4 times,*,6,start. Scroll down to Initialise Ram shipment set,start. It may ask if you want to reset the counter, if so say no and enter and stop to exit.
Now you can input the date and time and your ID and fax number (they may have been lost)
To set the date and time=
Function,7,1,set. enter the correct date and time and press set then stop. To enter the logo and fax number its the similar but its 7,2 this time.
Hope that helps.
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
6=RF Jam Detected
8=PC5204 AC Failure
2=Loss of AC Power
15helpful
Operating Instructions Model No BA218
Setting the time and calendar
1. Press the [TIME] button once to enter Time Mode. The display shows the current time with hour, minutes, and seconds digits.
2. Press and hold the [SET] button for more than one second. The "Hour" digits of the time will begin flashing.
3. While the "Hour" digits are flashing, press the [^] or [down] button to set the desired hour time. Note: Press the [^] or [down] button once to advance the setting forward or backward by one digit. Pressing the [^] or [down] for more than one second will accelerate the forward or backward setting at a higher rate.
4. When the desired hour time is reached, press the [SET] button again. The "Hour" setting will be confirmed and the "Minute" digits will begin flashing.
5. While the "Minute" digits are flashing, press the [^] or [down] button to set the desired minute time.
6. When the desired minute time is reached, press the [SET] button again. The "Minute" setting will be confirmed and the "Year" digits will begin flashing.
7. While the "Year" digits are flashing, press the [^] or [down] button to set the desired year.
8. When the desired year is reached, press the [SET] button again. The "Year" setting will be confirmed and the "Month" digits will begin flashing.
9. While the "Month" digits are flashing, press the [^] or [down] button to set the desired Month.
10. When the desired month is reached, press the [SET] button again. The "Month" setting will be confirmed and the "Date" digits will begin flashing.
11. While the "Date" digits are flashing, press the [^] or [down] button to set the desired Date.
12. When the desired date is reached, press the [SET] button again. The "Date" setting will be confirmed and the calendar setting is complete.
The Datemark will not print the time, only the date shows.
Please try going to Dymo's site at http://www.dymo.com/media/UserGuides/Time%20Manual.pdf I also had trouble finding the instruction book/owner's manual.
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top Foxconn Computers & Internet Experts
Jose Ramirez
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
