Question about Sharp AF-S120FX Air Conditioner
Sharp ASF120MX All of a sudden my AC will not allow me to put it in High while running either the AC or Fan. Still operates fine in Low and Medium. Any suggestions? Because of this I cannot set the timer as its default is maxium fan speed.
  • Anonymous Jun 12, 2008
    keep shutting down after a minute on. Then E-1 is displayed
  • 35 Answers
E1 fix
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Posted on Apr 29, 2009
How do I fix heater fan to operate at low and medium speeds. It only works on High.
depending on car some have a fan relay or its your switch itself
Jan 13, 2016 | Cars & Trucks
Why doesn't ceiling fan reverse?
Putting the fan in reverse is done by mechanically reversing the leads powering the motor. All the wall switch does is supply the power and the fan circuits take care of the speeds and direction.
Your problem is with the fan reverse control and/or electronics.
Sep 08, 2015 | Dryers
Ac fan will not run on high setting , manual or auto . when unit calls for high setting fan shuts down . Compressor continues to run and trips breaker in trailer . Someone thinks it may be the motor, but...
Most probably its weak motor.When the motor gets weak it trips/ stops on high setting.On high setting motor needs more power to run the fan.Try lubricate the motor .You may need a few drops of oil on the fan motor bearings. As they get older they get dry and gunked up. If you can see the bearings a few drops of oil may help. --------- Because the fan operates on medium and high, so loose wire or faulty fan switch is very rare to cause this problem.-------- As per the problem , it requires motor to be replaced.--------- This will help.Thanks.Helpmech.
Jul 29, 2011 | Dometic Rooftop RV Air Conditioner
Hampton Bay Windward II Purchased 2002 The fan has lost high speed. Low speed and medium speed work fine. When the fan is turned on to high speed it runs at medium speed. When switched from high to medium...
Most fans have a small rectangular multi-tap capacitor connected to the speed control in the fan. It is likely that this has gone partially bad. The capacitance values are printed on it. Lighting stores and big box hardware stores generally carry replacements.
Feb 23, 2010 | Dryers
My RV AC unit was runs good on high cool last night but this morning it was only running on low fan(some what cooling it Seems)What should I check first. thermostat,fan ???
low medium high speed of fan iscontroled by selector switch on the thermostat or recheck the thermostat if ok check control wirnig from thermostat to the fan relay on control borad and from relay to the motor.
Sep 03, 2009 | Dometic Rooftop RV Air Conditioner
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
No ac / fan only works on high
replace the AC blower motor speed control resistor, it is burned out
Jun 30, 2009 | 1993 Dodge Caravan
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Sharp AF-S120FX Air Conditioner Logo
146 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
