Kenwood BB5 Hello All, I have a Kenwood BB5. Power on and the relays click, click click. its the 3 relays on the left of the board. i tried to isolate the relays by removing them off one by one and found that all three of them do it. which led me to think its the control circuit for the relays and not the relays themselves. i also directly connected the points but the power amp wont come on. the rest of the systems come on. could you please help. THanks a million.
  • 1 more comment
  • Sajeevv Jun 12, 2008
    i fixed it
  • Anonymous Oct 05, 2008
    I have the same problem on BB5 Kenwood, I have jump the two connectors but the problem already exist.
  • thepawn May 11, 2010
    what's the C110? I can't identify it..thank you very much
Replace capacitor 110 (47uf 25v), it fixed the exact same problem for me, it should cost about 25 cents and take about 1 hour of your time :-)
Posted on Jan 06, 2009
Well all , My brother -inlaw came over with his unit ..Same Problem when you turn it on ..it just started a clicking sound , he has taken it to two diffrent places and both were unable to fix it .
so i jump on line and found this forum ..and did what you said removed the C110 cap.. and replaced it with one out of an old system i had ..and BINGO !!! it worked !!! ..So thanks all ..From him he was over the moon .. ( the system was in his shed for over 2 years because he could fix it ..So thanks again :)
Posted on Jun 21, 2009
I confirm is c110
Posted on Feb 12, 2009
Is your poer cable actually giving curent? Or ss your remote actually poweringon? Bad remotes are usually culprits if the power cable works fine...or a bad fuse. Give that a shot.
Posted on Jun 12, 2008
I had the same problem, and the solution was change the C110 capacitor.
Very very thanks.
Posted on Nov 17, 2010
  • parentinia Apr 18, 2011
    I confirm that in order to fix this problem the only thing to do is to replace the C110 capacitor (opposite side on the board respect the 3 relays).
What's wrongs with my beloved kenwood BB5 now /
The thing that clicks is a relay. They can and do stop working. However, the cause might be a fault in the power supply or in the main output causing an overload so the thing won't click.
Jul 28, 2014 | Audio Players & Recorders
On my Kenwood vr-505 Under the speaker symbol it says clip and there is no sound coming from the speakers
Hello. My name is Dave. Unplug the receiver. Plug it back in. When you first push the power button, you should hear one relay click. Within about 5 seconds, you should hear another click. My guess is, you don't hear the second click. Am I correct?
Dave
Sep 30, 2012 | Audio Players & Recorders
No Power up. Has 3 relay clicks when you plug it in. No LEDs light up and no flashing code from the stand-by LED. Have service manual. Where do I start?
hello the best thing to do is turn the power off take the back cover off and visual inspect the boards in side get a good torch and check for any bulging capacitors burnt resistors if everythink looks ok then you will have to check underneath the boards for any try joints i hope this helps
regards
shaun
Feb 23, 2010 | Sony KP-53HS30 53" Rear Projection...
Philips 42PF9967/10 blue light comes on the here a clicking of the relay then clicks off again and the blue light stays on and the red light at left of flashes
Your TV must have bad capacitors on the power supply board.
The tops of the capacitors will be domed/swollen.
Replacing the capacitors will fix the problem
when you take the back off, locate the plug wires from where they come into the back of the TV follow them up and it will end in the control board. search for the capacitor that would have bulged or swelled. This was not just take a quick look, it would be so slight that it wasn't even really apparent until we scrutinized each one.
Replacing this Capacitor would solve your problem
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 17, 2009 | Computers & Internet
Subs wont play
Hello debrahood196,
You first need to determine what is causing the "no sound" problem. (1) Try the sub(s) on a different amp (a friends maybe, or a local audio shop) and make sure that it/they work properly. (2) Test the outputs from the receiver. (3) Try a different pair of RCA cables. (4) Check the speaker wiring. (5) Check your head unit settings. (6) Check the amp gain. Once you have isolated it, repair or replace the defective wiring or part.
Hope this helps.
May 17, 2009 | Kenwood KAC-5203 Car Audio Amplifier
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
663 people viewed this question
 Grubhead
Grubhead
