HP Compaq FP5315  15" LCD Monitor
Problem for HP Compaq FP5315 (Black, Silver) 15" LCD Monitor
HP Compaq FP5315 15" LCD Monitor dead
By w8ENG on Jun 11, 2008
You have said a solution was "There are also 5 or 6 bad Capacitors on on top but as far as i know the only way to fix these power boards is to replace the components themselves as you can not buy a power board."
I am a technician at a television studio and we have a FP5315 that is dead. I have found a burnt/shorted SMD diode on the under side of the HV PCB. It seems you know what components cause the problem. I can fix it if you can proved more info.
Thanks for the help.
Same Problem
Jan 31, 2009
-   Power light and display constantly blinks. I can hear it going off and on-   Guest
Aug 28, 2008
-   I have a Hp Compaq fp5315 monitor.Power light(green)keeps blinking.Looking for someone who can fix it if I send the power board.
robert
biro100@bellsouth.net
-   biro100
Best Solution
posted on Jul 18, 2008
Very Helpful)
kp06
Rank: Master
Rating: 93%, 26 votes
yeah replace the caps and sometimes the 7.5v zener diode burns up too. I have been replacing the surface mount ones with just a regular through diode
Was this helpful?
Yes
No
Solution #2
posted on Feb 28, 2009
Not Rated)
vladimir23
Rank: Apprentice
Rating: 0%, 0 votes
Hi there, looks like undersized radiators and to much heat on the board. i am technician amateur and when the monitor was dead means power button was flashing and tiny sound off ticking was hearable i opened it and found over heated place around zener diode and few capacitors were on top rounded like overheated bud non exploded. so i just went to shop and buy glass zener diode 7v5. Putted all back it was running for couple hours and blacked again... diode were blowed. so second time i connected wires from zener place and started putting few zeners in parallel and measured voltage. it gradually increase voltage and heat. when i measured current going through it appear similar. so i decided to replace capacitors who doesn't look healthy. C922, 925 both 16V 1000mF, and C924 926 929 930 932 16V 470mF. hard to get them in my small town so i putted there 25V 220mF two times. I'd say that more volts will have more resistance against heat. wanted put some small fan but i couldn't find any 12V source on board and haven't got any 230V small fan. so i just drill more holes on bottom of steal cover. hopefully it will increase convection around board. thats it. i connected it and power on zener diode drop down and keep still and doesn't over heating. didn't measure current. just putted together and next week going to see how long it will last at my office. Sorry for my english and amateurism but i am just trying to share my few hours job. good luck Vladimir23  one more thing be really careful there are hundreds of volts all around board under power!!!!
Was this helpful?
Yes
No
Solution #3
posted on Aug 28, 2008
Not Rated)
biro100
Rank: Apprentice
Rating: 0%, 0 votes
I have a HP Compaq Fp 5315 monitor.Green power light keeps blinking .Looking for someone to fix the power board(if it's the problem)I can take it out to send.
Robert
Was this helpful?
Yes
No
Popular Solutions for HP Compaq FP5315 15" LCD
Questions and Unsolved Problems for HP Compaq FP5315 15" LCD
Do you recommend HP Compaq FP5315 (Black, Silver) 15" LCD Monitor?
Answer
Answer
Hi, i have the same problem. My brightness randomly changes, and a message comes up "Waiting... (More)
Answer
no volume on speakers, or not working at all.
Answer
it comes on and off will not come on all the way,i've chicked the power cord not that
Answer
I've just formated my computer and when i switch it on my Monitor comes clear then fades in... (More)
Answer
my compq nc4010 screen broke so im using the vga port on my tv the screen apeers during the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Compaq FP5315 15" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 736
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
