Question about Frigidaire GLMV168K Microwave Oven
Oven doesn't work
The power was turned off to my microwave for two days and when I turned it back on, the oven, fan, and turntable wouldn't work. Keypad seems to work fine.
  • Frigidaire Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 11, 2008
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
The turntable quit turning and it won't heat anymore, yet it has power-the fan works and the display works
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 15, 2011 | Dacor PCOR30 Convection/Microwave Oven
Microwave heats but fan and turntable wont work
hello,
what this means is that there is a disconnection of power supply from the wire connected to fan and the turntable,
the solution to solve this problem is to unscrew (open)the oven with electrical tools trace the wire to the fan and the turntable to locate the loose wire from it position fix it back with care or if there is any burn wire from those wire then the wire will need to be replace with another better.
please when doing this you will have to put OFF all forms of power supply from the oven.
thank you.
Jun 12, 2010 | Panasonic NN-S950WA Microwave Oven
Check this one out! My GE Profile microwave heats up but I don't hear the fan. However, the inside light and the turntable stopped working at the same time. Everything else seems to be working fine. What's...
hello,
this is a maize problem that wiring (wire) this means that your oven fan has been disconnected from it position
what you need to fix up your fan back is that you unscrew your oven trace the maize that supply A/C to the microwave
this maize is connected to different object but what by you are real after is your fan and the heater including the turntable .
trace the wire down to the fan to locate the loss wire from it position and do the fixing your self because it is same maize thaat link up both together i.e fan and turning table
please note before you can do this make sure that any form of power supply is put off.
Good luck and thank for using fixya.
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE DOESN'T WORK
32 years from a microwave!! Wow! Time for new. No parts available anymore. The smithsonian may be interested.
Oct 02, 2017 | Montgomery Ward Microwave Ovens
Whirlpool otr microwave
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Apr 18, 2009 | Microwave Ovens
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
GE turntable microwave Je1540WW 002 Turntable doesn't turn
I have had the turn table motor go defective in microwave ovens.
Normaly, before ordering a new motor, I always checked to make sure that there was power going to the motor assembly. I never had a power drive failure to a motor so-far. When they did not spin, the motor was defective. But, one day there will be a first time for me.
The fix was to purchase a new motor from the manufacture and install it. In some cases, I had to also replace the spindle key because the original broke when trying to remove it when removing the motor assembly.
I suggest that for servicing a microwave oven, you give it out to a service center to have the work done. There are safety issues when working on microwave ovens.
Jerry G.
May 25, 2008 | Microwave Ovens
Frigidaire GLMV168K Microwave Oven Logo
43 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
