Question about Sony KV-32S45 32" TV
Sony kb-35fbv1 35" tv
I have sound and the picture will come on but will go back black and keep flashing back and forth how do i fix it
  • Gary
    Gary Nov 16, 2008
    I have the same problem as well. I tried adjusting the top adjustment with no luck. A few things I noticed.
    When trying to press different buttons on the remote I find that the screen will stay on for a little longer when certain buttons are pressed, otherwise, the screen continues to blink.
    When the tv is first turned on there is only a black screen, then it will start to blink faster the longer it stays on.
    The place that you hook up the cable turns when tightening the cable to it once you get it just tight. I can turn this cable hook up on the tv by hand. I don't think it should turn.
    I hope that this helps to solve the problem.
    Thanks
  • lanciloti Dec 19, 2008
    TV starts out ok and then 10 seconds later the picture fails although I maintain audio.
  • 4,234 Answers
This can be a sign that the picture tube is starting to fail. If you feel comfortable working with the back off, try the following:
With the back off, locate the flyback transformer (part with large red wire coming out the top). There should 2 adjustments available on this transformer. Turn the top one (screen control) slightly clockwise, this should allow the set to work as expected. If that is the case, the picture tube is starting to fail and the adjustment has bought you time to find a new set. The lower control is for focus. Note: if you turn the control too much, the picture will be really bright and you will see the retrace lines as well.
Keep us posted.
Dan
Posted on Jun 11, 2008
On my 36in sony the picture goes in and out..from picture to black back and forth constiantly..im just clue less
a picture that blinks in & out every few seconds then it could be a bad tube.
I know the older models the picture would flash in and out with snow etc. that was a tuner problem.
haven't worked on very many sony wega's, maybe another tech here has a better ans.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Screen keeps flashing on and off
If the sound goes off too then there are bad solder connections, if it just the picture then the picture tube is getting weak, some times a picture tube rejuvinator can bring some life back for a while.
May 25, 2008 | Sony KV-35V35 TV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Have a 32 sony trinitron
Can you give me a model of the TV. It will be KV32?????
Nov 29, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Sony KV-32S45 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
