SOURCE: Sony MDX 65 6 disc changer installation
No, you have to have a Sony head unit or a Sony FM Modulator package with the uni-link connector on it.
SOURCE: 10 disc changer shows error code or no cd
maybe the lens in covered with dust , try to clean it , or it is broken. Who knows , break the device and see it for yourself. good luck
SOURCE: Blaupunkkt 5 disc changer
to take it out, you need two special toolsto insert in the four small holes on the sides. Since you probably don't have them, you can use four allen wrenches of the appropiate size. Just insert them and they will unlock the unit. (you might need something else to help you pull the unit very gently from one of the slots).
To reset the unit, I am not sure what do you meen by that. Just remember the unit has to be set up to work in the car's setup with the dealers interface module.
SOURCE: sony cdx-t69 CD Changer Unit
Bought a toyota with sony cd changer and had magazine stuck. Disconnected the cables at the back and left for 5 min. Hooked it back up switched to acc and pressed the eject button and came straight out. Didnt need to reset radio and retune.Now works fine.
