Question about Sharp AR-507 Copier
Problem with Sharp AR-507
Cannot seem to print from adobe and certian HTML pages. Jams up the copier and just hangs say it is processing data.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the paper jamming up in the copier?
    Is this the first time you have tried printing these types of pages before?
The Paper does not Jam. The copier just indicates that it is processing data but never seems to print. Seems to print every now and again if we change the fonts to download fonts. Not sure if there is an easy fix
Posted on Jun 17, 2008
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Dec 02, 2009 | Sharp AR-507 Copier
I want to connect my ar-507 gray digital copier to pc UBS port
Did you use a pcl driver? What was the error message?
Nov 19, 2009 | Sharp AR-507 Copier
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
Can't install
If you can ping its IP, you have that part correct.
What you may be having is a firewall issue.
If your firewall protection is not allowing an exception for that IP address, you can ping the machine, yet the data being sent will be blocked.
I have seen this several times in setting up printers, you have to go into your firewall and set up an exception for the IP address on your firewall.
I suspect that is the issue. Not uncommon.
Jan 16, 2008 | Sharp AR-507 Copier
SHARP AR-507 DIGITAL COPIER
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Nov 07, 2007 | Sharp AR-507 Copier
Sharp ar-m276 printing error message
There is a known problem with adobe 7 printing on this model. Unistall the PCL6 driver and re-install it using the PCL5e driver instead. This will fix your problem.
Oct 04, 2007 | Office Equipment & Supplies
Printer add on
Download the driver from sharp and install this as is seems that the windows default driver is faulty. Try this
Thanks J
Sep 22, 2007 | Sharp AR-163 All-In-One Laser Printer
Sharp AR-507 Copier Logo
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
