Question about Lowrance LCX-19C GPS Receiver
Waypoint altitude my lowtrance will not enter my waypoint with out an altitude. I do not have an altitude to enter, how do I get around this?
    Problem Solver:
  • 9 Answers
When asked for the altitude, enter it as 1.
Posted on Jun 24, 2009
How do I save a new waypoint on my garmin 76cx?
From your User's Manual Page 7:
You can create waypoints using three methods. Press the Enter/Mark key while at a location, create a waypoint on the Map page or you can manually enter lat/lon coordinates.
Press and hold the ENTER/MARK key until the Mark Waypoint page appears. A default three-digit name and symbol will be assigned to the new waypoint. To accept the waypoint with the default information, simply select OK.
To change any information, select the appropriate field and press ENTER to open the on-screen keypad. After entering and confirming the information you wish to use for the waypoint, select OK.
On the MAP page, use the ROCKER to move the pointer to the map item you wish to mark.
Press and QUICKLY release ENTER/MARK to capture the pointer location and open the information page for the map item.
Select SAVE. If there is no information for this point, a prompt will appear saying "No map information at this point. Do you want to create a user waypoint here?". Select YES.
If you require a User's Manual, you can view/download it from:
Hope this is helpful to you.
Good Luck!
Feb 27, 2011 | GPS
I can do the same ride with the unit on different bikes and get a variation in total ascent by as much as 200 feet
When starting your device, it acquires sttaelites progressively, then the altitude accuracy is not good at the beginning, so starting altitude and final altitude are not identical if you ride a loop.
Other possible cause is that the cumulation of small errors makes cumulative altitude to vary.
Garmin connect offers a feature that corrects the altitude by smoothing the waypoints, and also by using topology points.
Go to
Then upload your data from your garmin device to the garmin connect database, and use the feature named "altitude correction" bottom left of the screen where your ride is detailed
Aug 27, 2010 | Garmin Edge 305 GPS Receiver
I have a garmin edge 705. Every week I ride the same course. When I compare the graph of this same course they do not coincide. The starting point elevation is not the same aldo I always start at the same...
The reason is linked to startup of the device probably. I have same issue.
2 ways to improve :
1/ Startup your device
You need to startup device, and wait automatic change of the screen to the ride mode, from the sattellite search screen.
You also can check you have more than 4 sattellites before starting a ride. Altitude can only be computed when at least 4 sattellites are synchronized. So start your device in the open air, not indoor, nor close to a building.
Garmin devices start automatically and have probably a smoothing function that make altitude converge to the reality slowly from a started erroneous capture.
2/ Upload your ride on Garmin connect site, then apply altitude fix algorithm proposed. This algorithm will fix the altitude of your waypoints, both fixing pure altitude start issue, and also fixing denivellation computation, which is erroneous because of cumulation of errors.
Hope this helps
Apr 12, 2010 | Garmin EDGE 705
Can't seem to delete my wayward marks.
Delete your waypoints?
Find page > Waypoints
Scroll down to the waypoint you want to delete
Press ENTER and the waypoint details will come up
Move your toggle to the left to highlight the DELETE tab at the bottom of your screen
Press ENTER, screen popup asking "Do you really want to delete waypoint x? Highlight YES and press ENTER.
Nov 29, 2009 | Garmin eTrex Legend GPS Receiver
How do you set waypoints on the Magellan Meridian gold. To and from a location?
Press and hold the GOTO button for 2 seconds. A "Mark" screen will appear. If you are saving your current location, highlight the "Save" at bottom of screen and press enter. This will save you current location. You can edit the name of the waypoint at this screen also. You can do this before you save the waypoint or you can go to Menu/Database/User/Waypoint (the one you want to edit)/Enter. At this screen you can edit the name by pressing the arrow up or down to get to the name field and press "enter" to get to the alphabet screen. If you are entering a waypoint using coordinates, do the above but edit the coordinates to the ones you want to use and then save.
Sep 30, 2009 | Magellan Meridian Gold GPS Receiver
Tracking storage options GPSMAP 295
Every waypoint in the track has date/time, altitude and position. Second and subsequent waypoints will enable calculation and display of leg length, time, speed and direction between each par of points. The track can be displayed in 3D; in Google Earth for example. As far as I know there is no way to change the interval.
Jul 13, 2009 | Garmin GPSMAP 295 GPS Receiver
Waypoint selection uses last location instead of current location
Backup all data and reset the unit. Hope this helps...
Jan 14, 2009 | Garmin Rino 120 2-Way Radio
Entering map references manually
To enter a waypoint, either use Mapsource software and transfer to the unit, or else create a waypoint and then edit it to the proper co-ordinates.
Dec 01, 2008 | Garmin eTrex Legend GPS Receiver
Garmin gps 60 .How do i clear all waypoints?
In your manual, on Page 23. Press ENTER on the waypoint to view the waypoint information page, scroll to DELETE, press ENTER and the waypoint is deleted.
Aug 08, 2008 | Garmin eTrex Vista GPS Receiver
Setting a waypoint, I do not have the altitude and the lowrance will not enter the latitude and longitude, what do I do?
Assume an altitude of zero. It will have little effect on your accuracy even if you are above (or below) sea level. When you are near the waypoint the GPS will tell you the altitude and you can edit the waypoint then.
Jun 11, 2008 | Lowrance LCX-19C GPS Receiver
Lowrance LCX-19C GPS Receiver Logo
75 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
