Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Air flow I am getting an error message regarding the airflow and tv being turned off. After about 30 seconds the tv will turn off. But the fan in the back is working well, unless there are more then one fan.
  • yunks_r_us Mar 11, 2009
    How do I know it's the thermo switch.. don't want to purchase for nothing.
    Genius:
  • 1,030 Answers
The thermal sensor on the fan is malfunctioning... very common problem on these sets... mitsubishi has issued a service bulliteen to us service shops... basicaly u have to replace these sensors... wich involves removal of light engine to get to then readjustment of light engine
Posted on Jun 11, 2008
Air flow
Sounds like your evaporator is icing up. When the air is flowing over the evaporator it cools and dehumidifies the air. That water from the air will freeze over the evaporator and turn it into an Ice block. There could be many reasons this is happening. First check your air filter, crucial that it gets changed every 2 to 4 months, if its dirty then change it. Other reasons are that the condenser and or evaporator are dirty, could be low on refrigerant. Since you say the airflow is good at the beginning of the cycle then I'd rule out the fan having a problem.
So check your filter first but I highly recommend calling a pro to check the refrigerant level.
Apr 15, 2014 | Dometic Rooftop RV Air Conditioner
Air flow error message again and again....
A few of these sets did have a issue, the lamp cartridge had some fine metal mesh around a few places where the airflow from the cooling fan contacts it, that mesh if there gets blocked with dust and will give this error as it is really the set detecting the lamp temp is too high.
If you find that, clean the mesh free of dust, careful not to drive the dust inside onto the lamp face itself.
Other than that dust on the fan that cools the lamp can slow the fan just a little and the set will detect this also.
Dec 21, 2012 | Mitsubishi WD-Y57 57" Projection HDTV
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My y65 has a new bulb when I turn it on yellow light come on within a few seconds and a check air flow message come on the screen tv then turns off if I wait about 30 seconds I can turn it back on again...
ogrady1428,
I would check the filter on the fan intake first. Remove it and carefully clean it with compressed air.If this does not resolve your problem then I would remove the lamp and inspect the switch in the vicinity of the door for problems. Be very careful reassembling the unit once the door is removed. The interlock swich must be positioned correctly or you will get an error message. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem and how to fix it.
Thanks for using FixYa and for the generous rating. We answer these questions for free.
hardrocko
Aug 21, 2010 | Mitsubishi WD-Y65 65" HDTV
Cpu fan problem
If you plugged the replacement fan into the power supply instead of the "male plug on the mother board" you will get that error message. You need to find a fan that has the female plug for the mother board. It solved my problem.
Paul C.
Apr 22, 2010 | Nuvico NVDV3-16000N
Tv says airflow restriction tv will turn off. there is no airlfow restriction
I did not find a reference to airflow restriction in the service manual.
I don't know if this will help, but here are the error codes:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
4. Error Codes
The Error Code designations are listed below:
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Oct 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV air flow
open the back of the television to check for dust buildup on the heat fins and other components. As well as the fan.
Mar 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Cooling fan direction??
Yes, Massive air flow from the first fan is causing air to be brought in from not only the front of the radiator but from the fan right next to it causing reverse air flow through the fan. This intern can cause less dirrect airflow through the radiator. Also, the recirculation of hot air (from the first fan) into the second fan, across the radiator and back to the first fan can cause the vehicle to run hotter. Wile the car is moving there is enough air pressure from the outside of the vehicle to flow directly through the radiator with little fan assistance needed. If you have the engine running and and turn on the a/c, you should hear the fan change speed or even see the second one turn on (If the fan is working), there is no delay. You might have a bad relay and good fan, as there is a separate relay that activates this same fan for the a/c.
Feb 17, 2009 | 1998 Cadillac Seville
Canon W7200 Error code E02D05
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Probable problem locations
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Amber system light is on
had the same issue, we even had a personal fan blowing air behind the tv and the message always comes up right when we turn on the set and the tv turns itself off after about 30 seconds. did some research and it turns out there is no air flow problem just a faulty temperature sensor inside the set. Mitzubishi knew about this since 2006 but didn't really aknowlege it until more recently, they admitted it was a problem with the sensor and are now extending everyone's warenty by 2 extra years so if you got it with a year warenty and you bought it less than 3 years ago, call mitzubishi's 800 number and tell them the temperature sensor needs to be replaced, they'll get you in touch with the nearest service center and a service man will come out and replace the sensor at no charge for parts or labor. hope this helps
Jan 13, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
