Question about Chatterbox GMRS-X1 (15 Channels) 2-Way Radio
Chatter box GMRS X-1
Where can I get a coppy of the opperating manual for the chatter box GMRS X-1
  • 2 more comments
  • Anonymous Jul 21, 2008
    need a manual for the X1 chatterbox
  • federicomarc Aug 03, 2008
    I need a manual for the chatterbox x2
  • Anonymous Dec 20, 2008
    can anyone post it online so people would not have to do all that stuff!!!!!!!!
  • Anonymous Feb 22, 2009
    Can't find the manual online. . . emailed and asked, still haven't received a response. . .
If you call 888-452-2269 (Chatterbox USA) between 8 and 4 PST they can e-mail you the manual
Posted on Dec 01, 2008
You can go to the chatterbox web site and under the contact menu email one of the people listed and they will send you a manual free of charge. I just received my new manual.
Posted on Jul 22, 2008
1988 caddy with ****** chatter how to fix?
What kind of chatter? Is it from the outside front end of the car? Is it from loose metal? What is the detail you want to share to make an answer possible?
Jan 02, 2013 | 1988 Cadillac Sedan DeVille
Car doesn't start. when ignition is turned (new ignition) I hear a relay chatter and my horn sounds intermittely, Battery is new & tested goo
The chatter is due to low voltage. Check all the connections. The battery may have corrosion that lowers the voltage.
Oct 20, 2012 | 1999 Dodge Neon
My chatter box will not transmitt more than 1/2 of a mile
Well from my research, this unit outputs about 2 Watts. Now that's NOT a lot of transmission power, really. However I would still expect it to go more than 1/2 mile. The most important thing with any 2 way radio, is the Antenna. it needs to be mounted clear of anything at BOTH ends. Having ensured that the Power Must be 100% a bad battery will equal low output and poor sensitivity. Now if that's all OK, then the only other thing it can be is interference this can cause a lose of signal, as signals heterodyne with each other. As well check ALL wirings and connections for good contacts.Also if possible, test another unit out and see just what range you should expect?
http://www.chatterboxusa.com/images/downloads/manual-X1BT.pdf
Manual above.
Jun 05, 2010 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
Chatter by the exhaust manifold
possibly a warped or cracked exhaust manifold
Mar 21, 2010 | 1993 GMC Sierra K1500
I hae a electric heat pump and gas furnace, when utilizing the heat pump i get chattering from a relay, i have replaced this relay with a new one but continue to get chatter any ideas
chatter on a relay can mean a few things but since you have just tried to replace it, i wouls check the voltage at the relay,,,,
chatter is caused by i mproper voltage at the relay, coil,
Nov 03, 2009 | Heating & Cooling
Programing helmet chatterbox to cell
Push and hold the GMRS-X1 intercom button and turn the unit on, continue holding the intercom button down until the display changes to "BT" and the bluetooth indicator flashes. - then seek device's on your cell as usual, pairing code is 0000
Jul 07, 2009 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
Custom Wheels
I would check with the service manager at the dealer, they may have idea as to what is the cause.
Dec 12, 2008 | 2008 GMC Sierra 1500 2WD
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
Chatterbox GMRS-X1 (15 Channels) 2-Way Radio Logo
1,014 people viewed this question
Top Chatterbox Radio Communications Experts
eradiostore
eradiostore
Shaun Baxter
Shaun Baxter
Level 1 Expert
John L radiodude365
Are you a Chatterbox Radio Communication Expert? Answer questions, earn points and help others
