Question about Acer Aspire 5500 5570-2609 Laptop
Acer laptop log on problem
Hi thanks for your reply but i am starting up and when i press f8 at first it came up with a list i opted for safe mode and all it did was change the look of the screen but asked for a password again have ya any other ideas???
  • 3,940 Answers
When you get to the login prompt in safe mode, change the user ti ADMIN and leave the password blank, see if you can log in
If that fails, try ADMINISTRATOR
Posted on Jun 11, 2008
Forget the passwork for enter to laptop ,
1) Start your computer and press F8 rapidly continuosly
2) Then enter Safe Mode (This step takes around 1minute to FINISH)
3) Then you should be on the LOG IN page
4) Log in into ADMINISTRATOR
5) Go to Control Panel and change the password
6) Now restart computer NORMALLY without pressing F8
7) Now Log in into your account that you forget the password to! (Remember that you changed the pass to it in SAFE MODE)
Sep 21, 2013 | Acer Aspire 5515-5187 Notebook
Setup is starting services
First try to check if you can log to your computer via Safe Mode, if you can then there is a few possible things happened to your computer:
1. Corrupted software installation that is messing up with your startup services.
2. Hardware problem (memory or bad sector in the hard disk)
3. Or Operating system or malware.
Anyway for the step to test if you can log in via Safe mode try the steps below:
Reference: Safemode
Open Safe Mode with the F8 key
All Windows versions can be booted into Safe Mode by this method. Note that it is somewhat tricky to time this procedure and it may take several attempts.
1. Turn on or restart your computer.
2. Hold down the F8 key before the Windows logo appears. If the computer makes a complaining noise, tap the F8 key repeatedly instead of holding it down.
3. If a Windows logo or "Windows starting" appears, wait until Windows loads. Then restart the computer and try pressing F8 again.
4. Once you are successful, a menu will appear with a number of boot options. Use an arrow key to navigate to "Safe Mode" and press the Enter key.
Trying to get to Safe Mode by using the F8 key can be frustrating and there is another way that uses the System Configuration Utility (msconfig).
Best Regards,
Art
Feb 26, 2013 | Acer Aspire One Netbook 8.9" Notebook
How do I unlock or reset my password? Cannot get past log in screen. Acer Aspire One
Hi laura dish
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 15, 2011 | Acer Aspire One PC Notebook
I have forgotten the password on my acer aspire one notebook and dont have any hints to remember it. How can I unlock my laptop?
Hi. With VISTA
  • A. When laptop starts, please press "F8" key.
  • B. At the "Advanced Boot Options" windows, choose "Safe Mode with Command Prompt" and then login Safe Mode with available administrator account.
  • C. Input "net user", press "Enter" key and then all the accounts will be listed.
  • D. Input "net user Lisa 012" (Lisa is the forgotten account name and the 012 is Lisa's related account password.), press "Enter" key to finish unlock laptop Vista password.
  • E. Input "shutdown -r" and press "Enter" to restart laptop, then we can login "Lisa" account again.
With W7
  • A. Power on laptop PC and press the key: F8.
  • B. At the windows of Advanced Boot Options, opt for "Safe Mode with Command Prompt" and confirm with key: Enter. Then PC starts Windows.
  • C. Select "Administrator" account shown on the account screen, and then access the windows - Administrator: cmd.exe.
  • D. Input command: net user Merry 123 and confirm with Enter. (Merry is the account required to reset password; 123 is the new password for account Merry).
  • Please note that the administrator account will be useful only we had set it enable. (The default status is disable.)
Sep 03, 2011 | Acer Aspire One PC Notebook
My PC acer 5542G, win 7, laptop, after an upgrade programm on the ACER site for the driver sound (realtek), the screen become all black. But some fonction as light on the board and the cd-dvd driver are...
AFTER YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE. IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Computers & Internet
I have acer aspire when i turn it on only blue screen come on how can i fix it
Hi !
Blue screen means that your Hard Disk drive is damaged or dead and it cannot be repaired. Solution is to replace new the hard disk.
Good Luck and thank you for using FixYa !
Jan 06, 2011 | Acer Aspire One PC Notebook
Forgot my password to get in to my acer laptop please help
did you forget your windows password,or does windows not even boot up without the password
Apr 02, 2010 | Acer TravelMate 4100 Notebook
I have Acer 5315 laptop with window vista basic. I forgot the log in password. Can some one help me to start my laptop
hi..hit the F8 then run safe mode then run as administrator then remove the password..thanks and good luck...^_^
May 14, 2009 | Acer Aspire 5520-5908 Notebook
ACER ASPIRE 3000/5000 SERIES LAPTOP
Log on to your computer with safe mode
Steps
1. Start your computer
2. As soon as you see the first black screen when the computer starts , keep on pressing F8
You will see advanced options menu
Select " Safe mode with net working"
Now your computer will give you an option to log in with the administrator username
You need to log in with Admin and then goto control panel and change the password for your username ...
If this does not work then plz reply back stating the Operating system you have like windows XP, vista , 98 , 2000 etc...
Thanks and dont forget to rate!!!!!!!!
Jun 04, 2008 | Acer Aspire 3000 Notebook
I forgot my password
Restart your computer, pressing F8 while it boots up. You will see a list of boot options, select Start in Safe Mode. Log in as Administrator. You should then be able to change your user's password in Control Panel -> Users.
Nov 30, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
