Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Display problem i can't get the display to fit the screen edges of screen are not viewable
  • Anonymous Feb 04, 2009
    The Horizontal and Vertical Position cut the bottom of my screen off. I am running Windows XP (I have to for work- not that I'd like to run Vista).
    I'm calling tomorrow and if you don't see a post here, you'll know I didn't get any help!
  • 70 Answers
Try re-installing your video card driver, if you are using Windows, then use safemode to remove the Video Driver on your windows, and restart the computer and re-install the driver using the provided CD Driver for your video card.
Posted on Jun 11, 2008
How do I get water depths displayed on my C70
You haven't said if you have a DSM fitted ( sonar unit and tranducer) the C70 is only a multifunction display unit MFDU you then put a card in for navigation, a radar aerial/ scanner or a sonar unit for depth and fish finding .
if you have a sonar unit and it's working then
press Presentation
press Depth Digit and select on / off
press OK or cancel to return to the default display
hope this helps
Aug 28, 2014 | Raymarine C70 Multifunction Navigation...
Desktop only partially viewable on monitor
How to fix it depends on what operating system you use. For Windows right click on the desktop and choose Screen Resolution. Look under "What display should I use" and follow the instructions or simply drop the resolution down one step
Mar 18, 2014 | ASUS Computers & Internet
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Jan 30, 2010 | Samsung HL-P6163W 61" TV
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
Screen display size on Thinkpad A22p
your system might have damaged the systems video drivers and reverted to legacy.
try to re-install the display drivers again.
if you look in the system/device manager for the display it may just say vga , which can only give you 800x600 native mode.
if you right click on the desktop /properties
advanced /display adapter it should have the name of your video card.
Apr 30, 2008 | Computers & Internet
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
All edges are cut off in 1080i display mode
I have the same problem and have not been able to fix it either- i think it has to do with the glare screen on these TV blocking some of the viewable area.
Oct 27, 2007 | Mitsubishi WS-55805 55" Rear Projection...
OverScanning???
it sounds like a pin-cussion correction circuit failure. A tricky circuit to troubleshoot even for an experienced tech. check servicemanuals.net for info
May 14, 2007 | JVC AV-32F475 32" TV
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
122 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
