Question about Brother IntelliFAX 1270E Plain Paper Fax
Paper jamming in fax
When sending a multiple page fax, only the first page goes through. The additional pages will not feed through or they pull through crooked. I have to send each page individually.
  • 130 Answers
Look for a piece of paper in the paper path. clean all paper feed rollers
Posted on Jun 11, 2008
We can send faxes with no issues but when we receive a fax that has multiple pages after the first couple of pages we get half pages, partial prin or blank pages. We were told it was a possible system...
Is it pulling two pages at once? Sometime a machine will start to pull a sheet normally, then the page below it will get dragged along by the friction between the two sheets. One page's print gets divided between the two. If that looks like the case, pull out the paper drawer, remove the paper, and lightly sand the little rubber or cork pad at the front, then wipe the dust off with a damp cloth and let it dry. Before putting the paper back in, grasp the stack at one end, and "fan" the other, allowing air to get between all the sheets.
Get into the machine's Paper menu to see what size is programmed for the tray. If you have Letter size in there, but it's set for some other size, all kinds of feeding problems can occur, including false jams.
The paper feed roller is controlled by a magnet lever inside the right side of the machine. It should click once to start each sheet feeding. I've seen one Fax 4100e that clicked over and over, feeding extra sheets, just like you described. It turned out to be the system board. Worse yet, Brother had switched factories in mid-production of this model, and the replacement board they sent us fed paper just fine, but wouldn't do anything right on the phone line. Couldn't dial, couldn't answer. They sent another replacement, and it was exactly the same. Brother eventually broke down and sent a replacement machine.
Oct 06, 2010 | Brother IntelliFAX 4100 Laser Fax
Paper feed on send
Have you checked that you have no paper jams?
Nov 09, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Pulls multiple pages when sending fax
Problem :
feeding paper
Solution :
Clean in the feeder section all the rubber pads that pull the paper with alcohol
Aug 19, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Multiple pages
Actually, when you get more than one paper feeding in at a time, it is almost always the separation pad being worn down. Go here to buy a new sep. pad and tell them Ken from National Cartridge Co. sent you there!
May 28, 2010 | Brother IntelliFAX 5750e Laser Fax
Feed tray pulling multiple pages
prior to the issue ,it can be the sign of wear and tear of the feeder seperation pad .may i know is the fax heavily utilise.if yes get the part to change ,if no try to change your paper or frequently fan the paper it can be highly moisture present on paperand try to minimise using reuse paper it may shorten your machine lifespan.good luck thanks pls rate me!!!!
Aug 27, 2009 | Canon LaserClass 2050 Plain Paper Fax
Jammed frequecy
Open the printer panel and check for friction. Better still, contact a service technician near you.
Jun 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jam C84
Was the printer feeding multiple sheets at the same time, so that the sheer thickness of the wad caused the jam? If so, look into the slot where you load paper (this is called the automatic sheet feeder or ASF). You should see a small roller with a rubber coating. This is what pulls the sheets into the printer. Put one sheet of paper into the ASF and do a print. The Windows test print facility is convenient for this: start-control panel-printer and faxes, then right click your printer icon and select properties, then test print). If this works OK, put two pages into the ASF, then three etc. Observe what happens. If at some point more than one page is pulled in, it infers that the ASF is not working properly, in which case you will need to consult a technician (or have a go yourself at dismantling the printer). If the one-two-three-four etc page test doesn't produce a multiple feed, all it probably means, is that static electricity is holding the sheets tightly together. Make sure when you put a wad of paper into the ASF it has been fanned.
Report back on what you find, or if you have any queries on the above.
Jan 22, 2009 | Epson Stylus C84 InkJet Printer
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Brother IntelliFAX 1270E Plain Paper Fax Logo
150 people viewed this question
James Cagle
James Cagle
Jim Keysor
