Lite On LVW-5006 DVD Recorder Logo
Posted on Oct 31, 2010
Liteon lvw5006.disk will not eject - Lite On LVW-5006 DVD Recorder
I have a LITEON DD -A510. Door won't open. Bought another one on EBAY. Same problem. How do I get the door open?
LITEON DD -A510 2006 made new, 16 years old, many now are dead
is the clicker dead or missing or bad batteries in it or put in backwards. both clickers dead? you 2 now. RM-1 clicker.
second button front from left is eject. tell the seller it is no good.
RTM yet, be wise read it
https://www.manualslib.com/manual/360149/Liteon-Dd-A300g.html?page=15#manual
Can not eject tray to load DVD disc
the mechanism of your dvd are stucked up lubricate the moving parts and gears by using a small amoun of lubricating oil.to do it manually eject the loader by turning the gears by your hand..
I have a liteon rewriter The door will not open
There is usually an emergency eject. It is a small hole near the door. This runs the eject mechanism. Straighten a paper clip partly and push into the eject hole, straight in.
It is possible the writer has not completed a write on the disc due to a defect, power failure or a bad disk.
The writer maybe defective and the next disk will also jam.
Liteon dvdrw tray does not open
I had the same problem with my LiteOn dvd re-writer. It appears to be caused by a worn or slipping drive belt. I found the following link helpful http://www.mmmonkey.co.uk/console/other/360belt.htm
After manually ejecting the tray using a bent paperclip, the drive belt was easily removed, washed in warm soapy water, dried thoroughly and re-attached. Tray opened and closed perfectly. Still looking for a new replacement belt though!
1helpful
Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
1helpful
On my liteon 5005, i press''eject'' i hear clicks, but the tray will not open.help!!!!
Take a paper clip, bend it, and insert it into the small pin hole on the front of the player. It should be next to the eject button. This will open the tray up manually.
2answers
I keep getting error2131
I have got a samsung R700 and every time I try to burn a cd from the playlist it comes up with "error2131"
3answers
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Top Lite On Televison & Video Experts
Ngoro
ADMIN Eric
ADMIN Eric
August Brown
August Brown
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
