Sounds like you might have a faulty starter solenoid.trace the positive battery cable till you find it connected to a small canister.When you press your starter this should click.To confirm this take a meter that reads volts DC and have someone press the starter,you should have at least 12 volts going into the solenoid and 12 volts coming out.It will be the larger cable. Also check the two smaller wires for power,these are the ones that send the power from the button that activate the solenoid,closing the circuit ,sending power to the starter.Hope this helps good luck
