Question about Daewoo High Energy Efficiency Air Conditioner
Casement Window Placement of Unit Meant for Double Hung Windows
My casement window width is not sufficient to be able to mount allow me to mount the conditioner in the usual configutration meant for a double hung sash window. If I rotate the unit 90 degrees(angle) it will fit into the casement window width. Can the unit be operated in this position without creating any problems for the unit? Any problems created with rainfall on the exterior side of the unit in this position?
Or does Daewoo make a unit for casement windows?
Thank you,
FLB
  • lairtorrent Apr 16, 2009
    can i place the ac unit high in the window. If so how might I do it
  • John Wassenbergh Aug 13, 2012
    Usually not a good solution. A/C units are usually heavy and require the more substantial structure of the sill to be safely supported
I've had the same issue and solved it by installing the casement unit in the proper configuration (upright), leaving the casement window itself open (or, at least, closed right up to the side of the casement unit) then using a piece of plexigas to "close" the top section of the window. The plexiglass, when cut properly, will fit against the window frame and then some quarter-round moulding on the room side of the plexiglass will fasten it securely. You can add a bead of caulk on the inside to be sure there are no drafts/leaks. I've done this with two casement units in my home and have had no problems at all with the installations.
Posted on Aug 13, 2012
    Scholar:
  • 54 Answers
Http://www.mrslim.com/Products/Category.asp?ProductCategoryID=24
Heres an option for you I'm afraid you cant install an a/c unit In any position other than upright. Theres a unit size and type for every conceivable application though. GL!
Posted on Jun 12, 2008
Please anyone suggest me is it appropriate to choose Casement doors and windows?
The Casement doors and windows are best to to use as they are made up of UPVC which is a cost effective and long lasting. Casement doors and windows are resistant to heat, offer you proper ventilation and they are not prone to termites. So, don't think much, just go 4 dat. If you like more casement doors and design visit http://www.lghausys.com/in/product/windows/windows-doors-global-style.jsp
Oct 26, 2013 | Heating & Cooling
Why are double glazed windows rated so highly?
They are made of two panes of glass separated by argon gas. They are good insulators and protect window installations from condensation.
Aug 07, 2013 | Haier 9800BTU Slider/ Casement Window A/C
What are some different types of windows?
Some popular types of windows are are single-hung, double-hung, casement, bay awning, slider and Victorian.
Jan 10, 2013 | Building Materials
Casement windows, that crank outward, stick. This makes some of them impossible to close completely without pushing them in from the outside.
Don't know why this is posed in Chainsaws, but here goes. Check if the windows are 'square', meaning that there are good even gaps all around the window when it is closed. If not, the window may need to get shimmed to make it 'square' again. This is especially a problem on casement windows for bay or bow windows as they hang over the edge of the house. When properly installed, the weight of the window frame is tied into the attic rafters (on a ranch house) by wire cable so the window will not sag over time. If there is a framing support under a bay/bow window, it may need to be adjusted to bring the window back to square.
Aug 29, 2011 | Garden
Can it be mounted on its side? i have tall skinny windows
NO!!! You cannot do that you will have water everywhere!!!
Click here
This is the type you need... it is called a casement window A/C
heatman101
Jul 20, 2011 | Haier HWF05XC5 Air Conditioner
My air conditionner is not working properly. It sends cool aire keep getting code E3 What can I do to fix it Tks
micheline, according to the LG Owner's Manual for the Model Number you listed, there is no LED display on the casement window unit (please see the Owner's Manual link below). How are you getting an E3 error code? Or by chance, did you list the wrong model number? Even Goldstar, that is made by LG, doesn't show your model number.
Please advise. Thanks.
Jun 01, 2011 | Goldstar LG LC1200 Casement Air...
Has anybody found a manual for the Amana AP095R?
The included piece is not a template, but rather the piece the vent tube clips to. One side slides into the other and that allows for it being placed in windows of varying widths. I too had your problem with a casement window. I used a piece of plexiglass and screwed the round part to it and voila it worked. With my setup I was able to close the window (Pella). I later moved it to a double hung and cut the plexiglass to size. when we go out we remove it from the window. Easy peachy japaneasy.
Jul 18, 2009 | Amana AP095R Portable Air Conditioner
I have a kenmore casement model number 25378066890. I can clean the filter easily but I want to get behind the filter to made sure the front of the coils is dust free. How do I remove the cover to be able...
you have to remove the unit from the window and unscrew the cover which will allow you to clean the inside of the evap and condenser coil and oil the fan motor if it has oilers the easy way to clean it is to take it to a self use car wash. do not use the strong spray as it can bend the fins.
Jul 08, 2009 | Kenmore Slider/Casement Air Conditioner
Venting for portable air-condioners
They make special window units designed specifically for casement windows. They are taller and skinnier than standard window a/c's. They are no where near as common as standard window a/c's so you might have to look a little harder, but they are out there.
Jun 17, 2008 | Amana Heating & Cooling
Daewoo High Energy Efficiency Air Conditioner Logo
497 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
