Question about Canon PIXMA iP1500 InkJet Photo Printer
Printer error 1003
My printer, Canon PIXMA iP5000, comes up with error 1003, No paper, load the paper cassette properly. Obviously I have paper in there in the normal way I have been doing it for years. No obvious paper jams, bits sticking etc. Have switched printer/Mac off and on several times. Opened and closed all covers, pressed every conceivable permutation of switches. Still the same error message. Presumably there is some sort of microswitch or opto-switch to detect the presence of paper that is malfunctioning. Can you help?
Bought an Epson printer. Cheaper than a repair
Posted on Jun 12, 2008
Error Number : 1003 No paper. Load the paper in the cassette correctly and press the OK button on the printer. Plain paper of A4, Letter, B5, and A5 sizes will be fed from the cassette because...
Another possible reason for getting this error is a dusty printer. I don't dust very often so dust piles on everything, including my printer. My daughter wanted me to print something for her and the first page went through just fine. But the second never started and I got error 1003. I had plenty of paper loaded and my settings for the size of paper were correct. I dusted out my printer and everything else printed just fine. My theory is the top paper had dust bunnies on it that were pulled into the printer when it pulled the first page in. Maybe the dust got caught on a sensor that told the computer there wasn't any paper. Regardless of what happened, a quick cleaning fixed the problem. I just wanted to throw in my two cents for anyone out there that may have a dusty printer and run into this error.
Sep 08, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
Ella@hotmail.comI have 6 orange flashes to one green on a pixma ip5000 whaty is going on?
Hi
Please check your Printer Cartridge and check any paper jam is there, paper jam is there please remove the paper. and restart your printer.
Good Luck
May 11, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Jun 12, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon PIXMA ip4000/paper jammed problem
Tackler- I dont think I have a solution but I know that the cassette should stick out about 5cm i.e. the cover just fits on nicely. I found with mine sometimes it needed a firm (but not hard) push in as obviously some sensor was not being tripped and it would just not pick up the paper in the tray. Have you tried using the top down feed? At least if that works you can print (and you can stack up a couple of pages).
Oct 22, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
701 people viewed this question
old marine
old marine
Corne Viljoen
