Question about Packard Bell Computers & Internet
Front usb connections
Packard bell imedia tower with ms-6511 motherboard have replaced m/b but front usb not standard
  • michalpelszy Oct 17, 2008
    The motherboard has NON-STANDARD pin layout. It's something like this:
    _  *  * _  *
    Or numbered:
    1 2 3 4 5
    _ 6 7 _ 8
  • Anonymous Mar 17, 2014
    DVD decoder software driver needed for Windows XP
I finally found a solution, on a dead page in google cache only:
http://www.pcclub.com/forum/messageview.cfm?catid=27%26threadid=16567
The solution was posted by JontyBonkers.
The pins go like this:
1 2 3 4 5
_ 6 7 _ 8
1 = ground
2 = ground
3 = D1-
4 = ground
5 = D1+
6 = D2-
7 = D2+
8 = +5V
It seems that the case for those Packard-Bells had a small circuit board that divided the 5V line to both sockets.
D- are usually white, D+ - green, 5V - red, ground - black
Posted on Oct 17, 2008
    Scholar:
  • 93 Answers
Front usb jumpers on the board are usually a small cluster of 9 pins, usually found down the bottom of the motherboard, and labeled fusb, or USB_H, or something similar. the front usb connectors have 2 sets of wires (8 in total) and are black, green, white and red. if the front connector is one whole plug, just plug it onto the header the right way and it should go.. if the pins are all individual.. you will need to push them down one by one in the right order.. easiest wat to do it is plug both the black ones on the first 2 pins after the single one, then the 2 greens side by side, then the whites, and finally the reds on the very end.
. red . wht . grn . blk . blank
hope this helps
Posted on Jun 13, 2008
    Master:
  • 474 Answers
Usually the built in case USB connectors plug into your motherboard. there should be a set of metal pins that stick up and may say USB on the board next to them. You have to connect them in, usually the manual that came with the board will tell you where. But if your board doesnt have extra pins for external UDB then your out of luck. If you connect them wrong or backward they wont work.
Usually theres a + and a - indicating wher they go and the end of the USB wires will have indiviual pin connectors or one solid brick that all the wires go into and you just fit in on the mobo.
Good luck
Posted on Jun 12, 2008
    Sergeant:
    Champion:
  • 307 Answers
YOU CAN INSTALL USB CONNECTORS BY PCI BOARDS OR YOU CAN INSTALL USB CONNECTORS IN A UNIT THAT SLIDES IN TO WERE YOUR 5 1/2 OR 3 1/4 FLOPPY UNIT GOES. CARD PLUGS INTO MOTHER BOARD
Is there any way to make the BIOS on a Packard Bell iMedia S3810 motherboard UEFI compliant - I want to install a 4TB system drive...
In Short no it doesn't support it BIOS will any support a boot drive of 2TB
but you can add it as a secondary drive or use it in an enclosure as a USB drive
Sep 14, 2015 | Packard Bell Computers & Internet
On imedia should i connect the usb to speakers and green jack or only the usb?
Please do a monitor self test
connect a monitor without a cpu
or rather just connect a power cable to a monitor
if u get check video cable or something lyk tht its wrkng
if nt thn u l need 2 change the monitor
Mar 26, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
Usb on packard bell function slow (type usb 1.0)
This is normal. USB 1.0 is a lot slower than USB 2.0...why are you using USB 1.0 on a system that has Vista x64? Is it because of the device? Change the device...
Jan 12, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Packard bell imedia 5068
Ubuntu requires high graphic memory on your computer. It could install on some components but it doesn't work on whole installation process. If you are having a desktop machine, add graphic/video card to the motherboard so that Ubuntu will finally be installed in your computer.
Thanks
Jun 20, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Hi when i start up my packard bell imedia i get a red light on my tower my fan is spining and my monitor is on a amber light plz help
Assuming the monitor is fine you can try the following:
  1. Open the machine and reseat the video card; if video card is onboard try
  2. Unplug the machine and remove the CMOS battery for a few minutes; Its possible Windows didn't shut down properly and CMOS is preventing a normal startup; after replacing the battery, boot up (will probably start up in safe mode
If neither of these fixes the problem, you may have an issue with the monitor itself. Best of luck.
Greg
Jun 11, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Remove he dvd drive from Packard Bell computer
Remove both left and right panals on the tower. Disconnect the IDE ribbon cable and power from back of the cd drive. There also may be a small wire that connects ether to the sound card or motherboard also. Remove all screws from the right and left side of the device. Push the drive out the front.
Jan 19, 2009 | Packard Bell Computers & Internet
I have a packard bell imedia 5050 desktop when switched on only shows a orange light and will not power up from there can you help ?
Sounds like a power supply. the power supply in the tower may have overheated or burned. Does the fan in the power supply come one?
Jul 11, 2008 | Packard Bell Computers & Internet
Load error
open ur computer case and if u r using a sata harddrive try unplugging it from the motherboard and then again plugging it.it will work.i also had the sme problem and i solved it in this way
Jul 03, 2008 | Packard Bell iMedia SL 9553 (P660401806)...
Computers & Internet Logo
771 people viewed this question
Top Packard Bell Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
