Question about Canon PC-D320 Copier
Canon PC-D320 problem
We are getting a crease and smear that runs the length of the page for all copies that we are making. It always appears in the same location of the paper. While it is three years old the machine has only made 3,500 copies. We have changed cartridges.
  • MRondo Jun 11, 2008
    Mattozan:
    Any idea how an expensive a repair this is?
    Thanks
    MRondo
    Yes. We tried a new cartridge to see if that was the problem and it appears the cartridge is not the cause.
    Master:
  • 555 Answers
This indicates damage to the toner transfer unit (drum or belt).
Posted on Jun 11, 2008
    Guru:
  • 1,894 Answers
I think innk is smudging
  • dewan nafees ahmed Jun 11, 2008
    did u install new cadrige recently?
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
Slight crinkling of paper
You will need to replace the fixing film in the fuser unit. Unless you have done this before, I recommend having it serviced by a qualified service rep.
Sep 01, 2009 | Canon PC-920 Black and White Copier
Canon image D320 copier doesn't copy entire page
Dear sir,
its problem copier fuser unite
fuser cover is broken .Change it near by copier expert and then solve your problem
Aug 14, 2009 | Canon imageCLASS D320 Digital Copier
Copy is smearing from top to bottom on left side of paper about 1 inch wide.
The print in the smudged area, does it wipe off the page like not fused well to the paper. Do you also have a crinkling noise, if so the sleeve in the fixing assembly has torn. You may still have it under warranty with canon and can get it fixed for free.
Good luck
Bob
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Canon pc-d320 copying problem
You can take the machine off auto exposure and manually run the exposure darker using the exposure settting and + and- keys.
Apr 16, 2009 | Canon PC-D320 Copier
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Copy is not clear
Hi
The first thing you must check is the small scanner glass,this is the narrow glass that the machine is using when you use the dockfeeder,clean that glass and make sure there is no back dots on the glass.Even a small dot can cause lines on your page.But this lines will only be sen if you using the docfeeder.
The second probem can be the drum cartridge that is faulty.With this problem all your copies and printed pages will have lines.
If your drum is ok,the next thing that goes wrong is the fixing assy.
Jan 23, 2009 | Canon imageCLASS D320 Digital Copier
Unwanted "line" on copied documents
Open the document feeder and clean the scanner glass.
Jan 21, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Minolta cf900 maintenance tips
Dear Laker31,
you can find the right Tips ,on this Site:
http://solutions.konicaminolta.com.au/intranet/tsg/training/msds.cfm?b=CF900
Cheerup and Be Happy Always
Mar 14, 2008 | Computers & Internet
Canon PC-D320 Copier Logo
176 people viewed this question
old marine
old marine
