Question about Dryers
I need to turn off the gas from a gas dryer which has a small valve before the flexible tube that connects the line to the dryer. How do I turn off the valve?
  • 525 Answers
If the valve has a shutoff lever, vs a round handle, turn the lever so that it is pointing against the gas line flow, rather than in line with the flow. If it has a round knob like that of an outdoor water faucet, I would recommend a plumber come in and change it to a certified gas valve, and let him explain the function to you.
Posted on Jun 11, 2008
What diameter is the dryer side service connection? The gas connection on the dryer.
The gas inlet line to this dryer appears to be a male 1/2" "NPT" or "National Pipe Taper" fitting. You will need a 1/2" female NPT x by 1/2" flare fitting to connect a 1/2" flexible stainless steel gas line to the dryer. a 1/2" gas service line is sufficient to provide enough gas to the appliance.
You will need to determine what size the gas line and valve is at the gas valve service connection as well (the line and valve coming out of the wall or floor). They are usually 1/2" npt but can be 3/4" as well and may require a different size pipe and flare fitting.
Some jurisdictions may also re an "excess flow valve" to be installed. The service valve should be within 6 feet of the appliance.
Jul 25, 2015 | Maytag MDG7600AW Gas Dryer
Wont make ice and frozen water running down door
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Water and ice dispenser not working
Jun 06, 2010 | Refrigerators
My frigidarie refrigerator ice maker does't work
Jun 06, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
How do you get the ice maker to make ice consistently
Jun 06, 2010 | LG LSC27931S Side by Side Refrigerator
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I HAVE A AMANA FULL CAPACITY 7.1 DRYER THAT NEEDS A FITTING THAT HOOKS ON THE BACK OF THE DRYER INTO THE GAS LINE
If you are talking about the adapter between the flexible gas line and your dryer, your local hardware store will have it. I usually recommend that you take your flexible gas line with you so they can match up the correct size. The dryer gas pipe is standard. Good Luck, Appliance Specialists
Jan 04, 2010 | Amana ALG331RAW Gas Dryer
Low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Jul 03, 2009 | Weber Genesis E-320 Propane Grill
Kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Apr 20, 2009 | Air Tools & Compressors
Open Questions:
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
