Question about Refrigerators
Freezer section works, refrigerator becomes warm.
I open the back wall in the freezer and clean all the ice on and around the heater which makes everything work fine. But after 3 or 4 days, the problem comes back and I have to do the same thing. The fan works fine. I am thinking that the heater does not defrost, that's why the ice accumulates. Need help, what part to change.
yusafm@verizon.net
  • yusafm Jun 16, 2008
    Thank you very much 22yooper, your solution to my refrigerator problem was to the point and easy to follow.  If I had waited for your solution to come out, I would have saved some money. Now I  tell all the folks who have similar problem, to follow your procedure and fix it yourself. I panicked and called the technician who exactly did the same thing as you suggested and found out that thermodisc  was bad which he replaced and now my refrigerator is working fine. Thank you 22yooper. You are EXCELLENT.
  • 828 Answers
In the defrost circuit there are three major parts. Defrost timer, defrost heater(s) and defrost thermostat. Defrost timer failure will not put power to the circuit. Defrost heater failure will fail to defrost when the timer applies power. Defrost thermostat must be closed for defrost to take place. FIRST located the timer, rotate the Clutch head screw clockwise SLOWLY until one distinct click is heard. Timer will be in defrost mode and defrost should happen in 18-22 minutes after which the refrigeration should start cooling again. If defrost takes place and it does not go back to cooling automatically turn the screw once again until you hear the second click, unit will start. Replace the timer. If defrost does not take place in the time frame above and the unit restarts in cooling test the defrost heaters. From the heater(s) follow the wires from each end to where they plug into the circuit. Unplug them and test through the heaters with an OHM meter. You should get a reading if they are good, if no reading replace the heaters. If you get a reading on the heater(s) replace the defrost thermostat.
Posted on Jun 12, 2008
Freezer is working, refrigerator is warm
You probably have a defrost issue with the freezer. Cold air is passed to the refrigerator section from the freezer, when the freezer does not defrost air flow to the refrigerator is eliminated causing the refrigerator to warm up. Check for icing on the back wall of the freezer. If no ice on back of freezer, check the damper assembly going to the refrigerator section.
May 26, 2015 | Refrigerators
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
Freezer is not defrosting automatically and fridge is becoming warm The coils are icing up in the freezer
  1. take all from freezer side out
  2. open back wall
  3. check if the fan is damage
  4. check the heater element
  5. check thermostat
  6. one of them is bad
Jan 02, 2010 | Refrigerators
Refrigerator section not cold
u would need to replace heater and tstat and defrost timer depending on model
Mar 19, 2009 | Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Oct 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
687 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
