Question about EliteGroup P4VXASD (P4VXASD-R) Motherboard
Help me i want to know how can i repair my P4CXASD pc...it doesn't work nothing..i change my ram hard drive ..and graphic card ..but it doesn't work ..... How can i do... pls ...
  • steve quelnan
    steve quelnan May 11, 2010
    Please state clearly what problem you were encountering.
  • 55 Answers
Is your board completely dead?
It should at least beep without memory installed. It should start CPU fan.
1. If your board is completely dead, check your power supply.
2. Visually inspect caps around your CPU. If you see any bubbled tops, you need to replace those caps.
3. You also might have a bad CPU.
4. Try to remove a backup battery and wait for a couple of minutes before reinstalling it back. It might reset your CMOS and BIOS
Good luck!!!
Posted on Jun 11, 2008
Im runing a elitegroup a785gm-ad3 with a athlon II x4 and 2x 2gb ddr3 and 2x 1tb hdd and gforce 9500 ddr2 1gb card, the problem I have is when I switch my PC on it gives no picture at all, I've tryed...
when you took the graphics card out did you notice any dust in the socket
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty elctrical fan and its lead can cause this problem also the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jul 21, 2011 | EliteGroup A785GMAD3 Motherboard
I have old pc that worked for too long but after i bought new screen ( HP L1950 ) every time it says montior is going to sleep and some time it freezes forever and some time it says no signal but after i...
* check com cable all thru the video card socket,also check you video graphic card pci if its inserted properly,try to clean it first.
* might your pc is in Hibernate or Sleep mode
A power management mode that conserves power by powering down the system. In hibernate mode the current state of the system is saved to the hard drive, and the system will power down. When a user turns the system power back on, the saved information is read from the hard disk, restoring the last used settings. Hibernate mode is similar to sleep mode, however in sleep mode the power cannot be shut off.
go to control panel > power management and change or default the settings you wish.
Jun 08, 2011 | Computers & Internet
My pc is very low.I need fix
Slow PC does not mean it has problem only with motherboard. Speed of the PC also depend on the following factors :
  1. Processor
  2. RAM
  3. Virtual memory
  4. Operatin system
  5. Video graphics card
To fix the problem you should first check which type of processor is used in you PC. Is it pentium4, Dual core, Core 2 duo or core 2 quad ? Core 2 quad is much faster if used with 4 GB RAM. RAM is also the cause to slow the PC. If you are using less RAM automatically your PC will be slow. So use RAM higher i.e 2 GB or more.
Virtual memory does not have much impact on speed but it is also a factor to slow down the PC. But if you can correct any of the three parts then no need to check virtual memory.
If you are using operating system like Vista then computer may be slow. Instead use XP professional, Windows 7.
If your PC doesn't have graphics card then it will be slow while playing games, watching videos. So if you are a game lover then change your graphics card with higher value such as 2 GB or more.
If you will fix these problems then you can speed up your PC
May 29, 2011 | Computers & Internet
I am using intel 945gcpe motherboard...whenever i start my computer my hard disk produces a sound and processing get stops...this sound keeps on producing and my computer doesn't work....i have 250GB...
If your hard drive is clicking chances are that it is dead. This is not something you can fix. The motherboard will be able to support a 1 TB hard drive and can support up to 2 gb of ram. You can not put a graphics card in there since it only supports PCI. The only graphics card that can go in that slot are no better than the integrated graphics you have right now. I would suggest buy a whole new computer as what you currently have is outdated. Feel free to respond with what you are looking for in a computer and I would be more than happy to help you look for a new computer.
May 12, 2011 | Intel D945GCCR Motherboard
Hi, i installed a new hard drive and the monitor isnt getting a signal at all.
Is the system new? What is the VGA you use, on board or exteral? In case of an external VGA take a look if it fits ok at the mobo.
Waiting clarification, don't hesitate to post.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 22, 2010 | EliteGroup GF7050VT-M Motherboard
Lights and Fan are working, but no beep.
First open cpu cabinet.
Then refix RAM memory.
Pull cmos cell for 10 minutes so all settings of motherbord are defaults.
Then pull porcessor fan and processor clean dust from all chip and parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Motherboard won't go to boot sequence
Check the power supply if its giving the correct voltage on the mother board.
I know you're going to say it have power, but sometime it happens, It happend to me once, there was power and everything check everything and its working fine but when i put it back together nothing's seem to be working. I swap the power supply and bingo.
Mar 31, 2009 | ASUS P5S800-VM Motherboard
Asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Oct 16, 2008 | ASUS P5P800-VM Motherboard
955X7AA-8EKRS2 doesn't start
your pc doesn't give display this is the problem of RAM or GRAPHICS CARD. you must clean the RAM and graphics card with a soft cloth and then affix them
Dec 13, 2007 | Foxconn 955X7AA-8EKRS2 (683562472159)...
EliteGroup P4VXASD (P4VXASD-R) Motherboard Logo
80 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
