Question about Dell 3100cn Laser Printer
Dell printer 3100 cn laser
My printer is flashing load MPF 024-969 PLEASE HELP.
The MPF feeder door that is on the regular paper tray can jam when you load and slide the regular paper tray back into position. The fix is to close the MPF loader and pull out the regular paper drawer. Gently push the lower edge of the small MPF feeder door from inside regular paper tray outward. This will release the door to it correct position.
Posted on Sep 11, 2009
I had the dreaded 024-969 and was just able to print a test page.
I removed paper and reached inside the MPF. There's a spring-loaded lever facing upward, toward the back of the tray that the paper rests on and depresses. I toggled this up and down a dozen times.
I vacuumed out the entire tray area and then blew air into the same area by reversing the shop vac hose connection to the output hole.
Printer now prints.
Posted on Jun 09, 2009
I figured this out for myself. The printer was actually doing what it was suppose to do.
I got the error when I was trying to print a photo from a photo applicatioin, not a standard Microsoft application. For whatever reason the application was set to print as an "A4" document, which is a non-standard size--hence the "load paper" error. I just switched it to 8.5 x 11 and it printed fine!
Posted on Sep 13, 2009
I had an error code of 024-969 while printing C5 Envelopes. I tried the setting above but it did not solve the problem.
Then I tried with "MPF" and "Envelopes" and it worked
Posted on Jul 08, 2008
I had the same problem and followed the steps above and it worked!!!
Posted on Dec 01, 2008
I've found after fighting with the buttons on the printer that if you're accessing the printer through the network, it's much easier to make the changes on the printer's web page, rather than scrolling through the panel.
If you find the IP address of the printer, type it into your browser, and go to the "tray settings"
From there, you can set the paper type and size, click apply and click the "!" at the top of the page.
Posted on Sep 01, 2010
Make sure the door on your paper tray can move. I just went and fixed one of these, we opened the tray and the door was stuck a bit for some reason (it should open when you pull the MPF tray down).
Posted on Jun 24, 2008
If you've recently changed the type of paper that your using, this may help
-hit the "MENU" button
-scroll down to "Tray Settings", hit the center button
- "Paper type" will display, hit the center button again
- "MPF" will display, hit the center button again
- scroll to "Plain 1" then hit center button again.
Posted on Jul 03, 2008
My dell 3130cn printer giving the message load mpf?
The MPF is your Manual Paper Feed.
If you specified specialty media like envelope or card stock, the printer expects that to draw from the MPF.
It is also possible that the MPF isn't sensing when paper is present and you will need to replace that sensor.
Whit
Item, Inc
Aug 10, 2010 | Dell 3100cn Laser Printer
How do i load paper in the MPF
The front of you printer should open so you can access the MPF (Manual Paper Feed) tray. The MPF is usually tray No. 1 on most laser printers.
Mar 08, 2010 | Dell 3000cn Color Laser Printer
MPF 024-969
Is the paper pushed all the way back into the MPF?
If yes, what type/size paper is your application sending?
If you try to print the internal Printer Settings report, does it print?
This error typically means that no paper is sensed in the MPF OR that the wrong type/size paper is in the tray. (MPF settings do not match job specs)
Oct 27, 2009 | Dell 3010cn Laser Printer
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
My Dell Color Laser Printer 5110 cn won't print. It keeps saying ''Load MPF Letter'' then ''Load MPF Plain'' then ''Load MPF 020-969
it's asking for paper in the manual Paper Feeder (MPF). Somewhere in your settings you have it printing to the MPF. Check the settings in the printer prefrences, the printer itself and the software you're using.
Cheers.
Sep 23, 2009 | Dell 5100cn Laser Printer
Dell 3100 CN Prints a stip on black all the way
There is a known issue for these printers to "streak." If under warranty, call Dell. If not, there is a fix
for the defective drum unit design but requires a little technical expertise.
The procedure is explained here:
http://www.ahfx.net/weblog/133
Jul 08, 2009 | Dell 3100cn Laser Printer
A dell 3010 which prints fine from webpages etc. but refuses to print from out look and says load plain mpf 024-969 when there is paper in the machine which it was previously happy to print on.... very...
Outlook's printer options are set to load paper from the Manual Paper Feed (mpf) instead of the regular paper tray.
In outlook, select file->print and look for the printer properties button on that dialog box.
Select the paper tray you want to use (or simply uncheck "MPF" or "Manual Paper Feed") and hit OK.
Jun 14, 2009 | Dell 3010cn Laser Printer
Can't print. message load MPF won't go away
There is a print job waiting, either in the printer's memory or on your computer's memory. This print job is set to go to the Manual Paper Feed (MPF) which is accessible from the front of the printer by flipping down the little MPF door.
You can change settings for new print jobs, but once one job is submitted with "Please Print Me On The MPF" set, there's no way to change that job.
The easiest fix is to put some blank paper into the MPF and let it print out.
If it's spooled on the printer, you can turn the printer off and back on again to clear the job.
If it's spooled on your computer, you can view it by bringing up the Printer settings:
Start->Settings->Printers and Faxes
Find your 3100 and double-click on it.
Find the print job, select it and pick "Cancel" from the "Document" menu.
Mar 31, 2009 | Dell 3010cn Laser Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Dell 3100cn Laser Printer Logo
5,727 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
