I bought the nexxtech 5 button wireless mouse 2 weeks ago-(model # nwom5) it worked great until today when It just quite and yes I have tried replaceing the batteries,reconnected the mouse EVERYTHING
My parents are having the same problem. The mouse just died on them. While my mother was typing the mouse started moving slowly and then it stopped working all together. Does anyone have a solution to the problem? My parents are having the same problem. The mouse just died on them. While my mother was typing the mouse started moving slowly and then it stopped working all together. Does anyone have a solution to the problem?
Did you check the batteries to see if they are good. Some individuals are having to replace the batteries sooner then they should have to. Good place to start. Hope this helps. Bud
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Is this a wireless mouse? If yes, you need to isolate the problem. Please follow the steps below:
1. Use fresh batteries. 2. Connect the wireless receiver/dongle into different USB ports of the computer. 3. Make sure that the mouse is turned on and then try to reconnect the mouse to the receiver by briefly pressing the connect button on the receiver and then hold down the connect button on the mouse.
Try to take off battery and next push and hold down the small button that protrudes where the receiver is placed in the mouse, put back battery and simultaneusly release the button,it might make the mouse operate correctly.
Good luck!!!!
Chawah.
1) Do not ask questions in CAPS. It's bad form and considered rude in some forums.
2) It's a failed mouse. Replace it or call the manufacturer for replacement.
Same as above. Been working fine then just quit. Blue light flashes, but no pointer action.
I'm using WinXP Pro.
Just bought a new Nexxtech NWOM5. Lost receipt so can't return it.
Never worked at all. Tried all variations of instructions and on two different PCs. ZIP!
Anyone out there can help or should I just call it a loss?
