Question about Jensen MCD5110 CD Player
MCD5110 schematic Does anyone know where I might get a schematic for a Jensen MCD5110 radio? George
2 Suggested Answers
SOURCE: Need a replacement faceplate for my mcd5110 jensen AM/FM CD player
try ebay
Posted on May 20, 2007
I have the whole radio whithout a wire harness give me 50.00 and you will have a replacement radio in the future
Posted on Feb 19, 2008
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Need to find new wire harness for Jensen MCD5100
Jensen is now owned by Audiovox. Try going to audiovox.com.
Aug 02, 2011 | Jensen MCD5110 CD Player
Code ER8 when load of cd
I would try to take the cd out and reset by the little pin on or behind the face
Mar 20, 2011 | Jensen MCD5110 CD Player
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Jensen JCR-550 manual
Get it on internet,type www.jensen.com and download the manual is free.
Dec 22, 2008 | Jensen JCR-550 Clock Radio
Mcd5110 marine radio cd player
Gary, Sounds like channel 1 burnt out then channel 2 on the internal amp of the radio. If you are looking for another Jensen as a replacement they are decent for a lower priced radio. However if you are not operating your boat on salt water you could use a regular car unit. I replaced the radio in our boat with an generic import and I couldn't be happier. I bought something similar to this model here http://www.mp3playerstore.com/stuff_you_need/dvd/DVD-392.htm not bad for just over 100 bux add 150 for a LCD and watch TV and dvd's in the boat too! although if your lake house is like mine there are only 2 channels to watch :( Hack
Jul 12, 2007 | Jensen MCD5110 CD Player
Clock radio manual
Follow this link; http://spectraintl.com/ click contact us, then customer service. If anyone can help, it's them (they service and support Jensen clock radios), but they don't have a manual online Hope this helps :)
Feb 26, 2007 | Jensen JCR535 Clock Radio
Jensen MCD5110 CD Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
