Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Fills, then nothing
I too have a top load Ultimate Care II machine - last night, when used it, it filled, then nothing. No motor sound, agitator, nothing. Just sits there. I've tried the dial in different positions, but no luck.
Help, please.
  • 5,911 Answers
This is a symptom of a loose or defective lid switch. If you open and close the washer lid, you should hear the "clicking" sound of the lid switch as it is activated. If you do not hear anything, check to make the switch has not come loose. Sometimes a simple tightening of the mounting screws will re-align the switch to its proper location. If the switch is broken and does not function, click on the following link for advice on how to replace the lid switch for a Whirlpool washer.
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Most lid switches are located on the right hand side of the wash tub opening under the rim of the external case. There will be a small hole where a plastic piece on the lid (called a lid strike) pushes down on a contact. Make sure the lid strike is not broken off. This will also cause the same symptoms.
On other models, the lid switch is located on the left-hand side in the by the hinge of the lid under the washer casing rim. This switch is out of view and is activated by a rod on the lid switch hinge. Sometimes the rod requires adjusting to correct a simple contact problem. NOTE: Your washer will not have the small opening on the right-hand side of the wash tub rim if equipped with this type of lid switch).
Please post back if you require further assistance. I hope this helps you.
Posted on Jun 11, 2008
I have a Whirlpool Ultimate Care II washer. It fills and agitates but it will not drain or spin. When it hits the spin cycle it sounds like a timer is going off but nothing happens. Does anyone have any...
The only thing I can think of for this is a worn coupling for the motor. Does the noise sound simmilar to a grinding sound? if thee is no noise from the motor then I would suspect the timer. I have had both of these go out on me and they seem to be common problems. I hop this helps.
Nov 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont agitate
your dog ears are bad.
You can replace them for about $10 @ your local appliance store.
Aug 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
MY WHIRLPOOL LAUNDRY MACHINE WILL NOT AGITATE
If it just fills and stops dead then its probably the door switch.If it fills and you hear the motor start and it makes a horrible noise then its probably the coupling between the motor and transmission. Theres also a slight chance its a stripped agitator spline
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WUC II
check the lid switch, if it is ok go to the pump and see if anythig is in it, if nothing there motor issue
Apr 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills but agitator doesnt start; sensor problem
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
