Question about Canon imageCLASS D860 All-In-One Laser Printer
Wireless print server
Is it possible to attach this printer to a wireless print router?
  • 2 more comments
  • D Tacey Jun 11, 2008
    A little more direction on this please? What does "right interface" mean?
    Thanks - I needed to check for myself because I have a kid here who says that particular printer needs something else that cost about $200 to make it operate wireless. Any truth to that? It does have a usb and serial port on it.
    Yes. It is a Linksys WRT54GL with 4 ports.
    I have three computers set up on it via the little usb antennae. Nothing connected directly except for the dsl modem. It is over by the printer.
    So, if you don't mind, what do I need to do? Do I need another usb antennae to plug into the printer? I probably should download the driver also I would suspect.
  • Canon Master
  • 2,794 Answers
Yes you can as long as you get one for the right interface
Posted on Jun 11, 2008
  • 2 more comments
  • Tim Babcock
    Tim Babcock Jun 11, 2008
    If your printer is USB then you need a wireless USB print server. If it is a parallel interface, then you need a parallel USB print server.
  • Tim Babcock
    Do you have a wireless router already?
  • Tim Babcock
    You don't need nothing else then.
  • Tim Babcock
    You just need a wireless print server for your printer that is for USB printers.
How to print wireless to my printer
You need a printer with a built-in wireless system, or buy a wireless router with a server port, and then attach your printer in this router. It will define a IP to your printer that will be visible over all you network.
Nov 06, 2013 | Office Equipment & Supplies
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
Will my x2500 print wireless?
It is not possible to connect this printer wirelessly because it only has an USB connection to a computer unless you attach this printer to a print server and then to a wireless router.
Alternatively you can set up this printer as a Shared printer on a computer on your 10baseT LAN network. Other computers on your network can then printer to this printer provided the computer with the printer is switched on (booted up).
Jun 04, 2011 | Lexmark X2500 All-In-One Printer
Can the epson R220 print wireless
It can't print wirelessly with the native hardware. It has a USB 1.1 connection. You may be able to find a print server that can connect to a wireless router. However, you will need to check the specifications. Some print servers will only work with select printers or OS combinations.
The specifications for the R220 are here: http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&infoType=Specs&oid=58654761&category=Products .
I hope this helps.
(note since this is an older printer with a USB 1.1 connection, you can expect the printer to be slow with a wireless connection. If your signal strength drops, you may need to reboot everything (computer, print server, router and printer).)
Mar 21, 2011 | Epson Stylus Photo R220 InkJet Printer
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
ALTERNATELY
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Can the epson rx560 be attached to a wireless router
Your printer needs to be wifi capable in order to connect to a wireless router.Please its manual.
Dec 08, 2009 | Epson Stylus RX560 All-In-One InkJet Photo...
Is it possible to set up the printer for wireless printing?
This is not a wireless printer, however, you can create a wireless envirnoment by using a wireless router or a wireless printer server router. Linksys and others carry the routers for around $40.00. You would hook the printer directly to that router and the router would have an IP address that all wireless devices could see.
Good Luck.
Mark
Nov 29, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have a wire less network set up and want to use my lexmark x1270 so i can print wireless but cable is USB and do i need to get a cable to put into my router or??
You can't set it up wirelessly, persay. but you can use a special bluetooth adapter in the "pic bridge" slot on the front. I have seen them on e-bay from £5($8) to £12($17) or so.
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Canon imageCLASS D860 All-In-One Laser Printer Logo
50 people viewed this question
old marine
old marine
