Jvc tv I can't seem to get my jvc tv to switch to channel 3 (so I can use itwith our cable system) It goes directly from 2 to 4 or 4 to 2. We don'tseem to have the remote any longer and I can't find a function anywhereon the tv to erase pre-sets.
  • MsDebbie Jun 12, 2008
    sadly, this doesn't help since I can't get to the menu without the
    remote--or at least there doesn't appear to be a way to do so.
  • 71 Answers
Go to menu and scroll down to autoprogram-with cable box turned on- and run autoprogram; it will pick up ch#3.
Another option is to use video inputs and take video and audio using RCA connectors.
Posted on Jun 12, 2008
My neighbor has acquired a jvc tv/vcr combo w/ original remote. when she wanted to program it for cable it only seemed to do ch. 33 - 79 channel 2-32 did not show up. We also could not figure out after...
Your cable company has probably started distributing 2-32 as digital channels. The JVC only has analog NTSC capability. You can acquire an inexpensive digital tuner for around $40 to solve the problem.
Oct 27, 2010 | JVC TV-20F244 20 in. TV/VCR Combo
I accidentally hit the menu button on my tv and seem to have reset something. It goes from Channel 126 directly to Channel 24 and will not set to channel 3, which is the only one that works with my cable
Hello
You have hit the channel skip function to on. Go to menu and come towards functions where you can see channel skip. Keep it to "off" position. Now it is in "on" position.
Oct 16, 2010 | JVC AV-27530 27" TV
I have a JVC tv model AV 27495. I hooked it to the cable with the cable cord. I can only get cable 2 channel. I can't access any channels. What do I need to hook into the cable? Do I need a box since...
Yes, with the Direct TV box it did all the tuning and your TV had only to be on one channel, normally ch 3 or ch 4. Now that it is not there any more your TV tuner must do the work. You now will have to tell the TV to search for channels. Use your remote and TV menu to do this. You will be able when the search is complete to see some of the cable channels but other premium cable channels you won't be able to see without a cable box.
Sep 12, 2010 | JVC Televison & Video
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
JVC LT 32E479 UNABLE TO SWITCH ANY CHANNELS
go to menu select TV settings select add a channel  In the scan boxes  type 1 and 3 or what every you have your Satellite set to  Then hit start scan  The TV will come on reset to channel 3.
Jan 14, 2009 | JVC LT-32E479 LCD TV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Home theater
Just go into your sat box setup menu and under setup system option select audio and make sure to go to the dolby digital option and turn it on. This feature is turned off by default from the factory. You will always get 2 channel sound unless that is on. Also remember to go to a hd channel as they are broadcast in surround sound and non hd channels are broadcast in 2 channel.
Nov 08, 2008 | JVC THD-50 System
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
