ACER ASPIRE HI THERE, I TRIED WHAT YU SED AND NOW IT KEEPS LOOPING FROM"LAUNCH START-UP REPAIR(RECOMENDED)OR STARTWINDOWS NORMALLY.IF I CLIK ON REPAIR IT JUST KEEPS LOOPING BACK 2 THIS SCREEN AND IF I START WINDOWS NORMALLY ITLOOPS BACK 2 THIS SCREEN 2...I,M WELL CONFUZED.. THANX..PAUL
  • 4,889 Answers
Ok.. I thought you said its a new Pc and the problem with boot up usually indicates a troublesome HDD. I would suggest that you utilize the warranty while you still have it..
Posted on Jun 11, 2008
Acer aspire is stuck in repair loop
From cold start, try F8 and if granted a choice to load as normal, choose that. If normal load succeeds, after Windows finishes loading, restart the computer. This should store a normal registry, i. e. one that does not direct you into a loop. I probably would subsequently use an sfc command but to avoid describing that I would simply suggest downloading Glary Utilities and going to the system repair menu item that will replace/repair system files. That takes a long time but then you know your system files are not corrupted. And I would reboot again, then.
But for you, here is a link that describes how to free yourself out of the endless loop if the above is of no help:
Windows 7 help and support forum
Sep 05, 2017 | Acer Computers & Internet
My acer laptop is not start up
Try start normally or better still use F8 at start up and choose safe mode. That sometimes sorts errors out.
Feb 04, 2014 | Acer Aspire 6930-6771 Laptop
I have a acer mini laptop aspire one d270 with windows 7 starter.I have just now discovered that my laptop is not starting.It is showing me two options: 1)launch startup repair(recommended) 2) start...
You always want to start your windows normally.
In my 10 years as a computer technician I have learned that you never use the startup repair option cause it will never help.
Any more questions or concerns feel free to contact me Country Tech Repairs
Oct 21, 2013 | Acer Aspire One PC Notebook
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
My Acer Aspire 5720-4258 turns on fine but then it says to choose either Launch Startup Repair (recommended) or Start Windows Normally and I have tried both but none of the two work I cant get passed this,...
you just start your pc when it shows startup sreen press f8 and enter to safe mode in safe use the acer erecovery management software to recover your pc.
Aug 28, 2011 | Acer Aspire 5720 6497 Laptop
Why is my laptop is stuck in start up mode. solution 1 did not work, the screen i come to has 2 options launch repair and start normally, the launch repair does not work but the start normally option is...
Hi you should keep on tapping F8 while booting so that an option will appear to select safe mode. or if you have a recovery CD restart the computer then press F2 or Delete to access the Bios Page look for Boot Options and change the first boot priority to your CDROM restart the computer and just follow the instruction on the recovery disk.
Thanks for using Fixya.
Feb 05, 2011 | Acer Aspire 5920-6335 Laptop
Mine wont go past the "start computer normally" or
It could be a failing hard drive. Typically, if it keeps happening that is where the issue may be. It could be a video driver, or another driver too or a recent windows update.
Oct 31, 2010 | Acer Aspire 7520-5757 Notebook
My Acer keeps on checking the file system on C: for consistency--after it is finished I get the screen to start windows normally and it will start the check all over again
have you try to check volume errors ?
From My Computer, right click the Drive (c:) then Properties, click Tools tab and then click Check Now, shut it down and restart.
Or you can even click Defragmentation, but it will take a long time.
Be sure to back up your impotant files before do Defragmentation, just in case.
Sep 06, 2009 | Acer Aspire One AOA110-1588 Notebook
Acer 3680 will not boot up.
try to boot in safe mode, if you can then from there try to remove the latest software or hardware you install.
if you are unable to boot in safe mode, then try to repair or reinstall the os.
plz post your findings
Jun 06, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
