Question about LG DLE5977 Electric Dryer
Bought Dryer 2 years ago and just recently, last week, used for second home and getting error code on display tE1, thermistor open. What and where is the thermistor? Can it be replaced?
Thnaks Gary O.
  • 525 Answers
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Posted on Jun 11, 2008
  • David Emmel
    David Emmel Jun 11, 2008
    I am sorry, I missed,(or forgot), that it was 2 yrs.old. If the dryer worked ok the last time you used it, then I would think that a power surge may be responsible for the failure. I would disconnect it from the power supply for 10 minutes and power it back up to see if a static discharge helped. If not, then the control board may need to be replaced. Part no.1359831.
    Follow the link below for more information.
    http://www.repairclinic.com/SmartSearch/...
TE1 error...thermistor seems fine
that's a bad thermistor,the thermistor isn't alot of money it's like 15 dollars,change it out,remove the code anf go from there but it should fix it,also check the wire connections.the tech sheet will tell you how to get it into diagnostics to remove the code
Nov 24, 2013 | LG DLE5977 Electric Dryer
Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Mar 05, 2010 | LG Dryers
My lg dle5977 electric dryer is not completely drying my clothes, what can i do about it?And also how do i take it apart?
If the dryer is heating the most likely problem will be clogged or restricted exhaust. Make sure you are getting good airflow to the outside of your home when the dryer is running. Also check to make sure the exhaust on the back is not closed off and especially make sure that it is not crimped.
Feb 21, 2010 | LG DLE5977 Electric Dryer
I ran the dryer without the lint filter in it and now it is noisy
First of all, You have a serious safety issue. Your dryer may catch fire. DO NOT USE YOUR DRYER.
Something went into the mechanism (yes, may be another sock), and a lot of lint went inside the dryer. The dryer needs to be cleaned by a technician. Using the dryer on its condition may cause a fire. Don't get your house burned down just to save some money doing it by yourself.
Aug 30, 2009 | LG DLE5977 Electric Dryer
LG TD-C70040E dryer shows ELE/EHE code ....
This happened to my LG dryer and I took of the raised back panel that covers the flywheel and there is a red reset button. This worked for me.
Good luck
Funny how this happened after 3 years exactly. hmmm
Jun 14, 2009 | LG DLE5977 Electric Dryer
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
LG DLE5977 Electric Dryer Logo
362 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
