Question about Samsung Televison & Video
CCA Values For Samsung TV
Model is HLP4663W. I replaced bulb, ballast and color wheel. TV now operating OK. B/W movies and other b/w screens now have ugly green when they should be black. I bought a short service manual, and have the colors on auto. A truth table(CCA VALUE) came with the color-wheel, no instructions. It is a matrix of 12 numbers. Need info or suggestions on how to use remote to get to a service screen. Others say it is a 6-7 step process with this service screen. Still others say to use remote, press "mute 1 8 2 pwr" or "menu 1 8 2 pwr". Tried these. Don't get any service screen, just tv turns on.
Please provide any help that you can. Regards, Joseph Yurko
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Posted on Oct 17, 2008
  • 1,284 Answers
Send me an email tvtek (at) and I have 2 files to send you regaurding this repair.
Posted on Jun 11, 2008
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Replaced my Samsung HLP4663W color wheel and the
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Nov 11, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Black Solarization
The speed of the color wheel needs to adjusted or the CCA values. Both are found in the service menu . If you paid a company to fix the TV, call them and tell them that they forgot to perform these alignments. If you did the repair yourself, you'll have to call around for a price to have a Samsung service center perform these adjustments. I don't recommend consumers access the service menus of modern TVs because one wrong button push and you may cause irrepairable changes to the TV's proper operation.
Feb 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Need to fix CCA Values for my Samsung DLP HLP50563W, got a new color wheel
The new color wheel should have come with a sticker that has a table on it with a bunch of numbers filled in. I think you enter these numbers into the TVs maintenance mode: using the remote with the TV turned off, press
mute 1 8 2 power
The TV powers up and you will see a menu on the left side of the screen. I don't know the exact procedure, but look for something called CCA and then enter the numbers from the sticker.
I just replaced my color wheel and it came with the sticker, but I did not know what it was for. I lost the sticker (probably got thrown out with the packaging). Now must buy a new color wheel and take better care of the sticker.
Oct 17, 2008 | Televison & Video
About the color wheel option
Hello Brandon B,
look on the side of the unit there will be a sticker with Model number, serial number and Version code. The version code will tell me what color wheel you need. There maybe some CCA adjustment you need to do using the remote in Service mode. Let me know what the version number. We will go from there. You can contact they will walk you through the installation process
Best regards
Jun 23, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
310 people viewed this question
Jerry Greenberg
Jerry Greenberg
