My Magnavox TV is Model MS3252S431. Is it capable of receiving over-the-air digital broadcast signals? Martha B. Swart dickandmartha@bellsouth.net
  • marthaswart Jun 12, 2008
    I consider myself to be somewhat computer literate, but I do not get all the acronyms used in techno-speak. I do not know what ATSC is and could not find a reference to it in my manual. I believe my computer was purchased in December of 2004.
    Martha Swart
  • marthaswart Jun 13, 2008
    Thanks! I have already ordered the $40 coupon--they say they will be sending them out on July 4--so then I can proceed with getting up to date.
    Thanks again. This is a great service!
    Martha Swart
    President:
  • 1,284 Answers
Most likely not. How old is the TV? If it doesn' have a ATSC digital tuner you will have to purchase the digital to analog tuner available at most electronic stores now. Apply for a $40 voucher from the government to apply towards the purchase. Here is a link to apply for a coupon online.
https://www.dtv2009.gov/ApplyCoupon.aspx
Posted on Jun 11, 2008
  • Don
    Don Jun 12, 2008
    I apologize for for that but ATSC stands for Advanced Television Systems Committee. Which means the TV would have a digital tuner. The old process was NTSC wich was National Television Systems Committee. Being manufactured in 2004 it won't have a digital tuner (very few sets did) so use the link I supplied before to obtain the $40 coupon (2 allowed per houehold) to then purchase the digital converter box you will need. Go to
    http://antennaweb.org/aw/Address.aspx and enter in your address to see what if any digital stations you will be able to pick up from your location and the size of antenna that is needed. Basically if you can receive UHF (channels 14-69) right now you should have no issues with picking up digital signals. Digital pictures will be without ghosting and grainy images. They are far superior to current analog signals. Hopefully that helps..
Will my toshiba tv bought in uk work in usa
There are two things you need to know regarding your TV.
Power requirements and broadcasting standards.
1:POWER
Look on the back of the TV and find the sticker or label that mentions the INPUT VOLTAGE.
If it reads 220-240V 50Hz then it will not work in the USA.
If it reads 110-240V 50-60Hz then it MAY work in the USA. At least you know it will work if you change the plug on the mains cable.
2: BROADCASTING
In the UK, broadcasts use the PAL system to display images on the screen. In the USA, broadcasts use the NTSC system to display images on the screen.
You need to check the manual that came with your TV to see if it is capable of receiving an NTSC signal. This signal is used in everything in the USA from PVRs, to DVD/HDD recorders, satellite systems, public access and cable systems.
If your TV meets the power and broadcast requirements then it should work.
May 24, 2015 | Toshiba 50H82 50" Rear Projection...
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
I have a wd-60735 tv if i hook up a convertor box to it i get air channles if i just hook up the antenna to it it wont find any channells what could be the problem? Thanks
As of 6/12/09, the over-air broadcast signals went to digital (ATSC) only. Your set does not have and ATSC tuner so it can not receive the new digital signals. The converter box converts the ATSC signals to the NTSC channel 3 or 4.
Dan
Jun 19, 2009 | Mitsubishi WD-60735 Projection Television
HELP !!! I HAVE 5 CONVERTER BOXES AND STILL "NO SIGNAL" APPEARS.
you could try waiting or .. make sure you tv is in "digital" not "analog"
May 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
1- I have a Panasonic TV (PT-53TW54)that has a "digital scan rate of 1080i,540P". I'm not sure if that means it has a digital tuner. Do I need a digital converter for this unit? 2- I'm using a...
1. Do I need any additional equipment to watch HDTV broadcasts on my HDTV-compatible TV?
In order to view over-the-air (OTA) HDTV broadcasts, you need to be within the reception area of a TV station broadcasting HDTV signals. Some TVs may require a set-top HDTV tuner and an external antenna to receive the broadcasts. Your cable or satellite provider may also offer HDTV channels as a part of their service, eliminating the need for a separate tuner. Please contact your local service provider to find out what kind of HDTV services they may offer.
2. What is CableCARD and how does it work?
HDTVs with CableCARD slots can accept a small card from your cable provider that allows you to receive standard definition and high definition digital broadcasts without a bulky set-top cable box. Please call your cable company to find out if they offer this service in your area.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif3. What is HDMI? Is it compatible with DVI?
HDMI, which stands for "High-Definition Multimedia Interface", is the consumer electronic industry's first connection capable of transmitting uncompressed digital audio/video signals. Components featuring HDMI can transmit both digital audio and video over one convenient cable, replacing the tangled mess that resides behind many home theater components. HDMI also offers improved quality over traditional analog connections thanks to all-digital transmission. Digital sources like DVDs and HDTV programming can now be transferred digitally from source to display without analog conversions that can degrade the original signal.
Unlike the HDMI interface, DVI only handles digital video. Through the use of an adapter, a DVI device can be connected to an HDMI device, but only video content can be transmitted. The audio signal would have to be transmitted through other methods such as analog RCA outputs or an optical digital output.
4. What's the difference between 720p and 1080i HDTV broadcasts? Does my CRT projection HDTV support both?
HDTV signals can be broadcast in either 720p and 1080i. It's up to the broadcaster which signal format to use, and both have their benefits. Our CRT projection HDTVs display 1080i signals in their native format. For 720p broadcasts, you can use the settings on your HDTV set-top tuner, cable box, or satellite tuner to convert a 720p signal into a 1080i signal that your TV can display.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif5. Why do I still see black bars on my widescreen TV when viewing certain widescreen DVDs and HDTV broadcasts?
Your widescreen TV has an aspect ratio of 16:9 (1.78:1), which is the aspect ratio of HDTV. However, movies are filmed at several different aspect ratios, including 2.35:1. Also referred to as "scope", 2.35:1 is a very panoramic aspect ratio that provides a wide field of view in the theater. Scope is much wider than your widescreen TV, so it still requires the use of letterboxing ("black bars") to fit the entire image on screen. Some TVs and DVD players have a zoom function that allows you to blow up the image so it fills the screen, but the sides of the image must be cropped in order to do so.
6. What will 4:3 broadcasts and DVDs look like on a widescreen TV?
There are multiple settings for adjusting the appearance of 4:3 material on Panasonic widescreen TVs. It can be viewed with black bars on the sides, preserving the way it was originally intended to be viewed. Some viewers find the black bars distracting, so they might prefer one of the stretch modes that lets you fill the entire TV screen with the image. One such mode is the JUST (justify) mode, which stretches only the outer portion of the picture while leaving the center untouched.
Oct 21, 2008 | Panasonic Televison & Video
I have a Sanyo CLT2054 TV. Does have a digital tuner so I can receive digital signals from a DVR and Digital broadcasts? Neill Parkin
Salutations nrparkin,
I hate to say there maybe some misunderstanding of the features of your television. After reading your owners manual it shows that you should only be able to pick up standard NTSC analog boradcasts not the ATSC digital broadcast standard.
Your television is a EDTV which means its an Enhanced Definition Television allowing a display of 480P. You may still need a digital converter to pick up the current and future digital broadcasts over the air.
Hope this helps.
Jon
Go Ahead. Use Us.
May 15, 2008 | Televison & Video
RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
Feb 10, 2008 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
