Question about Dell PowerEdge 1600SC Server
Automatic power on
Hi
In some computers is possible configure an automatic "Power On" from "Power Management Setup" option (BIOS). How can I get the same result in a Power Edge 1600SC .... ?
  • jaguarz12 Jun 13, 2008
    Hi David
    Thank's, I think the same, my Server should be on all the time, but I need to know how to do this. I need turn off my Server every day of the week. That's decission was taked by my Boss.
    However, thank's
Hi
I do not know why you need the automatic power on for your server. Server should be on all the time 24/7 .
If it is a PC , then you should know that even though shutdown , they are still on (you can see a light) .
This means you can use magic bullet to wake it up (wake up on lan).
Read up on magic bullet.
Good luck,
David
Posted on Jun 13, 2008
Sleep button won't activate
I'll assume you're referring to the Sleep option accessed through the shutdown menu in Windows. My bet is you'll have to make a change to your power plan in the Power Options section of the Control Panel. You should see a few pre-configured power management options like "Power Saver" and "High Performance." To the left of these options should be a sidebar containing more specific and direct links to changing how your computer behaves and what options are available.
If you cannot resolve your problem through using the Power Options under the Windows Control Panel, I suggest you enter your BIOS setup (you'll have to restart your PC), and press the right arrow key until you're on the last page of BIOS setup. Once there, press the down arrow key until the option to load "default settings" is highlighted, and then press enter. Then highlight the option to exit saving changes and press enter, allow the computer to boot normally into the Windows desktop, and check the sleep option again. You may have to select the default BIOS settings before making changes in the Control Panel, but I would recommend trying the Control Panel first.
Jun 01, 2014 | HP Pavilion Media Center m8530f...
How to enter bios setup to toshiba dynabook satellite 1850
1. Enter BIOS Setup
1. Press the Esc key while powering on the computer.
2. Press the F1 key, when prompted.
2. Change the Virtualization Technology option
The Virtualization Technology option is in the OTHERS configuration pane on the right-hand side of page 1 of the BIOS system setup.
1. Press the O key to select the OTHERS pane, and use the down arrow key to move down and select the Virtualization Technology setting.
2. Set it to Disabled.
3. Change the Configuration option
The CONFIGURATION option is on the upper left-hand corner of page 2 of the BIOS system setup.
1. Press the PgDn key to go to the second system setup page.
2. Press the O key to select the Device Config setting and change it to All Devices.
4. Change the Display option
The DISPLAY configuration option is on the bottom left-hand side of page 2 of the BIOS system setup.
1. Press the D key to select the Power On Display setting and change it to LCD+Analog RGB.
5. Save the changes by pressing the End key and then the Y key to. Be sure not to press the Home key -- which restores the default BIOS settings.
Aug 14, 2011 | Computers & Internet
I want to disable the system password on my dell computer
I assume that you have the password? Restart your computer. As soon as you see the dell screen, hit the f2 key. This will take you into setup. Look through the different menus and you will find the password options somewhere. You should be able to disable it there.
Mar 02, 2011 | Intel D865GBF Motherboard
Computer wont reboot can you help me fix it
possible cause is that Windows XP was installed with the wrong power management hardware abstraction layer (HAL). Verify that power management is enabled in the BIOS. Open the Power Options applet from the Control Panel, click the APM tab, and turn on Enable Advanced Power Management support. If you don't see this option, the system is likely configured with the ACPI HAL and your problem lies elsewhere.
You can also reinstall Windows XP and manually select the ACPI HAL during installation to overcome potential power management issues with hardware (such as video cards) that does not support APM.
Oct 23, 2010 | Computers & Internet
My monitor says going into power save mode and goes off. The computer tower is still powered up and the power light on monitor blinks. when I press the power button on momitor it says monitor working check...
Disable Power Management on Windows 7 or Vista If you are using a desktop computer, chances are that you don’t want the computer to go to sleep automatically. This is even more the case if you are running Windows 7 or Vista in a virtual machine for testing purposes.
Disabling Power Management in Windows 7
Start by clicking on the power icon, and open up the More power options:
sshot-2009-10-21-23-05-42.png Under the “Additional plans” section, select High Performance, then “Change plan settings”:
sshot-2009-10-21-23-06-52.png Then change everything to “Never”, and save the changes:
sshot-2009-10-21-23-07-41.png Disabling Power Management in Vista
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link:
vistacontrolpanel%5b1%5d.png Then click on the Power Options link:
poweroptions%5b1%5d.png Then select High Performance:
highperf%5b1%5d.png This will disable the automatic sleep mode, but will still turn off the display. You can click on Change Plan Settings to disable that as well if you want.
Jan 26, 2010 | Hannspree HANNS-G 19" Widescreen Monitor
My ACER ASPIRE AX1300 gives blank screen
Configuring Power Settings Using Power Options in Control Panel, you can adjust any power management option that your computer's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To configure your power settings:
1.
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options.
2.
Or, if you see the little battery indicator on your task bar, right-click it and then click Adjust Power Properties
I would put it on always on
Nov 28, 2009 | Acer Computers & Internet
Windows will not turn computer off. I have unpluged every thing and all fans but the hard drive. I get 0.01 dcv when the computer is running and the same when I try to have windows turn the computer off....
This usually happens if Windows is having trouble closing a program. The easiest way to avoid the problem is to close all programs before you close Windows.
If that does not help, you need to track down which program is causing the problem.
If you are running Windows 95, remove all shortcuts from your StartUp folder.
If you are working with 98/ME/XP, uncheck all the programs listed in StartUp in the System Configuration Utility (you get to the utility by opening Start/Run and typing "msconfig" without the quotes in the Run box and then clicking on OK).
Shut down the PC. Reboot. Shut down again.
Then add one program back, shut down, reboot and shut down again.
If Windows shuts down as it should, add a program back to StartUp and repeat the shutdown, reboot, shutdown routine. Do that until you have pinpointed the errant program and reinstall it. If you are running a screen saver, consider it also to be a prime suspect.
Your Advanced Power Management, or APM, utility has decided to take leave of its senses.
Disable it, both in your BIOS file and in Windows.
That little sound riff that accompanies the shutdown is hitting a sour note.
Go to Control Panel and click on the Sounds icon to open the Property dialog box.
Scroll down in the Events box until you see Exit Windows. Change the sound settings to None.
Your TEMP folders are bulging at the seams.
If the C:\Windows\TEMP folder gets overloaded, all sorts of bizarre events can ensue. Clean it out. While you are at it, clean out your Temporary Internet Files folder as well.
Updating XP with the latest Service Pack may also cure the shutdown failure.
However, it is also possible that Advanced Power Management, or APM, is getting in the way of the shutdown routine.
APM may not be enabled in your XP configurations, but it may be turned on in your BIOS, a memory-resident program that controls how your PC sets itself up.
Microsoft recommends that you go to the Control Panel, click on “Performance and Maintenance,” and choose Power Options.
Click on the APM tab and click on Enable Advanced Power Management Support.
Personally, I don’t like automatic power management on desktops because it can cause all sorts of bizarre behavior. I would leave Advanced Power Management disabled in Windows and turn it off in the BIOS.
Consult your PCs manual to determine how to enter BIOS’ Setup file. Sometimes, as the PC boots, you can see a message on the screen that tells you which key to press to enter Setup. Press it before the screen welcoming you to Windows appears.
Once in Setup, look through the various sections until you find the option for controlling power management. Choose to turn it off.
For guidance on other XP shutdown problems, consult article 308029 in the Microsoft Knowledge Base. Use the article number as a search term at the support site below. Good information is also available at the aumha.org site.
Regards.
Aug 27, 2009 | Computers & Internet
Upgraded mem.now mon pc dont shut off fan con to run
Computer doesn’t power down when users shut down
In some cases, Windows XP’s Setup program can misidentify the power management scheme in a computer’s BIOS as Advanced Power Management (APM) instead of Advanced Configuration Power Interface (ACPI). When this happens, users will notice that the computer no longer automatically powers down when they shut down Windows XP. Instead, they’ll see the message It Is Now Safe To Turn Off Your Computer and be forced to manually press the power button to turn off the computer.
You can verify this problem by checking the power management configuration in two places—Device Manager and the Control Panel. To quickly access Device Manager, select Start | Run, type Devmgmt.msc in the Open text box, and click OK. When you see the Device Manager window, locate and open the System Devices item. If Setup identified the system as having an APM-compliant BIOS, it will be listed as a Standard PC in the System Devices tree. (If it were identified as having an ACPI-compliant BIOS, you would see it listed here as a Microsoft ACPI-Compliant System.)
To check the power management configuration in the Control Panel, open the Control Panel from the Start menu. If the system is using Category View, select Performance And Maintenance and then click the Power Options icon. If the system is using Classic View, just click the Power Options icon. If Setup identified the system as having an APM-compliant BIOS, you’ll see an APM tab in the Power Options Properties dialog box. (If the system were identified as having an ACPI-compliant BIOS, you wouldn’t see an APM tab.)
You may be able to fix this problem with a BIOS update. To begin, check with the computer manufacturer’s Web site to see if it’s providing the latest BIOS update. If you’re troubleshooting an off-brand computer, you may be on your own as far as tracking down the BIOS update. Here’s how.
Once you obtain and install the BIOS update according to the manufacturer’s instructions, you must perform what I call a Refresh Installation, in which you reinstall Windows XP on top of an existing Windows XP installation. You must perform this reinstall operation because the power management features are tied to a special power management Hardware Abstraction Layer (HAL). During the Refresh Installation procedure, Setup will completely redetect all installed hardware, including the updated BIOS, and rebuild the power management HAL as well as the part of the registry in which information about the installed hardware is stored.
Jul 20, 2009 | Gateway M280E
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Dell PowerEdge 1600SC Server Logo
282 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
