Question about Admiral AW22 Top Load Washer
Admiral dryer-top loading-won't heat but spins
What could this be?
  • 246 Answers
Thermal or high limit fuse. Usually located near the heating element. You can check continuity through these with a continuity or volt meter while the unit is unplugged. If one of these is bad, check your venting also for a restriction or blockage. Possibly you have a bad power lead to the outlet (tripped breaker, fried wire, etc) but this can only be checked with a volt meter or simmilar device.
Posted on Jun 16, 2008
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
Mar 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
My admiral heats up but doesnt spin found the problem its the belt but which way does idler wheel go
If you are referring to the spring loaded tensioner it goes on the smooth side of the belt
Feb 03, 2013 | Admiral Dryer Belt 31531589
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Door Switch
Wiring
Won't rinse/spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 06, 2011 | Admiral AAV7000A
Admiral top load stops spinning after about 20 seconds when trying to spin to empty water
Check the drain pump on the bottom of the unit often the hose will block causing this issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Admiral AW22 Top Load Washer
Admiral washer will agitate but will not spin dry
heatman101
Sep 19, 2010 | Admiral AW22 Top Load Washer
Admiral machine won;t drain water
If the machine is spinning then the problem will be a blocked pump, this is driven off the motor when spinning so is a simple impeller in a casing, remove the pump and check for debris inside.
Dec 06, 2009 | Admiral AW22 Top Load Washer
Admiral top load 10.1 Kg 4 speed Combo has become
water does not stay in drum goes straight out?
Jun 04, 2009 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
60 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
