Question about Samsung SyncMaster 940MW 19" LCD Monitor
Turning on the TV
Lately, it is necessary to press power button on remote for five or so minutes. Eventually it will come on. The red light flickers when you touch the button 'Power' and eventually it will stay on and the TV screen lights up and there is no problem until we turn it off and after 1/2 hour or so, it will again take numerous attempts to get the screen on. For the past 2 days it will not come on at all. No TV screen and no flickering light.
  • 1 more comment
  • cozican Jul 06, 2008
    Takes over an hour of holding the channel up button for my tv to turn on used to take 5 min to turn on nows its buggerd
  • arnold_ford Sep 03, 2008
    samething, hit the remote or the power button, and it takes a few tries to get it to light off, like a relay is not closing all the way in it.
  • Anonymous Jan 15, 2009
    Can't turn on my 940mw. Power cable works, so the monitor is getting power. No lights. nada.
Pulled mine a part to look things over , power supply on mine has capacitors that look like they are going bad , would not be that hard to pull the power supply, and put in some new ones. i let my kid have it to play games on, as long it's on, it works, so leave it on.
Posted on Oct 14, 2008
Sounds like a bad power supply. It it's external you could just replace it, if it's internal, you will have to get it repaired.
Posted on Oct 13, 2008
Seems like a hardware problem. why do you turn it off?
Posted on Jun 19, 2008
Tip
How to fix your PS3 when it's frozen at startup
1.The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
2.Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
3.Time to enter Safe Mode.Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
4.Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
5.Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
6.Select option number 3, (Restore File System). Then select yes to perform step.
7.You will then see this screen. "The hard disk's file system is corrupt and will be restored."
8.First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
My tv is not working right with picture.
Press the TV button on the remote, make sure the TV is plugged in, check the electrical outlet to make sure it is live if the TV does not turn on. If these actions do not solve the problem, press the Power button on the front of the TV. If the TV turns on, replace the batteries in the remote control and reset it by pressing the number 1 button for 60 seconds. If necessary, reprogram the remote.
Unplug the TV for two minutes, then plug it back in if the buttons on the remote don't work. Make sure the remote is in TV mode.
Change the settings on the sleep timer if the TV turns off unexpectedly. Unplug the TV and wait five minutes before plugging it back in if necessary.
Check your antenna connections and cables if the sound is okay but the picture is poor. If all the connections are good, adjust the sharpness function.
Jul 21, 2011 | RCA 20F512T 20" TV
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
The sharper image jumbo touch panel remote control, can program every appliance (tv, dvd,etc.) except my directv hd receiver. no codes listed in booklet for the hd receiver, tried the codes for regular...
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
  1. Place the jumbo remote and your old remote on a flat surface, head to head, with a 1" to 2" space in between (the remotes should be aiming at eachother).
  2. Press and HOLD the device button on the jumbo remote (eg. TV) until the jumbo remote's small indicator light turns solid red.
  3. Press the LEARN button once on the jumbo remote. The light will blink rapidly.
  4. On the jumbo remote, press the button that you want to perform the learned action (eg. If you want the jumbo remote to turn your TV on and off, press the POWER button on the jumbo remote).
  5. Press the same button on your old remote (eg. POWER button on my old tv remote control). When the jumbo remote's light changes from rapid flashing to slower flashing, press ENTER on the jumbo remote.
  6. You're done! Try the jumbo remote out (eg. Aim the jumbo remote at your TV, press the jumbo remote's TV button, then press the jumbo remote's POWER button). Your television should turn on or off with your jumbo remote.
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
Jan 04, 2009 | One For All URC-9910 LCD Remote Control
Picture stays on black
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Programing universal remote
Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
Jan 20, 2008 | Televison & Video
Trisonic ts-rc488
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY JAC1NJ@AOL.COM , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Aug 19, 2007 | Trisonic TS-1666RFS Remote Control
Samsung SyncMaster 940MW 19" LCD Monitor Logo
318 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
