Question about Brother HL 5140 Laser Printer
Drum light The drum light comes on every time I try to print. The printed copy is good but the light always comes on. We replaced the drum but the light continues. Is this a problem or what can I do to stop it?
  • DakotaSteve Jun 19, 2008
    I have a similar problem. The drum light comes on and stays on --- not
    described in the manual. (Status light is green). The printer won't
    print at all. (It's just one problem after another with this printer.)
  • Anonymous Feb 26, 2009
    It worked. Thanks!
  • 3 Answers
You need to reset the drum count. Open the toner door. Hold the "Go" key until all 4 lights light up. Let go of the button and close the door. That should reset the drum count and stop the blinking.
Posted on Jul 24, 2008
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
I have a Brother MFC 8220 with a nonBrother cartridge and the original Brother drum. No problems printing until today. I tried to send a 4x6 piece of thin card stock through the front manual feed on the...
There are possibly 2 reasons why this is happening.
1. The drum unit may have been damaged in some way but I doubt it. Check fully that all contacts are in the right place at either side of the drum unit. A contact may be slightly bent.
2. Check the Transfer Roller is in its correct position. The transfer roller is the felt type roller that is positioned in the printer under where the drum unit goes. If this has got out of position then that could also cause the faint printing. Check contacts in printer are not bent.
May 19, 2011 | Brother MFC-8220 Fax
My Brother MFC 7840W prints but has a faint copy of the previous paragraph about 3 inches below. I have cleaned the corona wire very thoroughly but still the 'ghost' printing on my documents. How do I fix...
Yes. The drum is most likely your problem. It is possible that it is a one time problem, which can occur if you print a very dark black page or image followed by a light gray page or image. If it has only happened once or twice try printing a different document to check it. If it is happening repeatedly, then you should replace the drum and instantly see it fixed. You can get a drum anywhere that supplies toner.
I hope this helps! Good luck!
Feb 28, 2011 | Brother MFC 7840W Printer
I own a Sharp Al-1655CS about 2 yrs old, I have a problem, the balck toner powder is exiting the back of the machine and copies are very light. The copy count shows 12,000 copies made. I have repalced the...
These are very good machines so I would see no reason to replace it. Do you have the operators manual? If so look up the setting for "toner save mode" and make sure it is NOT turned on.
The drum unit is good for at least 18,000 pages so I would not suspect the drum. I even reset the counters on the drum units and can get up to 36,000 pages on them. Do you have the machine hooked to a PC for printing? If so is there any difference between printer density and copy density? If so then the issue is with the scanner density setting. If the copy and prints are both light then it is a print engine problem. If several toner cartridges are doing the same light print then I would suspect that your laser scanner optics are dirty. There is a narrow strip or slot just above the drum unit that the laser beam goes thru to write the image onto the drum. This should be cleaned and then the machine re-tested. If no improvement is see then the machine will have to be dis-assembled and cleaned which would require a compentant service technician.
Good Luck and Thank You for using Fixya.
Aug 14, 2010 | Sharp AL-1655CS Laser Printer
Switched printer on to print unable to print drum light flashing-
Remove and reinstall drum / some times will reset drum switch.
Or the drum life has been used. Drum only good for 8 to 10 thousand copies.
Aug 12, 2010 | Brother HL-2040 Laser Printer
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Four dots middle of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Sep 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Drum Light
You need to rest the drum count.
Open the toner door - press "Go" until all 4 lights light up
Let go of the button and close the door and you should be all set.
Jul 22, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
1,391 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
