Question about Weather King 10AJA2501AH Air Conditioner
Condensation pan replacement
I am trying to find a condensation drip pan for model # caoc6ab62mc a weather king or summit forced air unit. Let me know if you can help please.
Thank you,
Mark
    Novelist:
  • 148 Answers
Im one of your techs i did some research thanks
Posted on Jun 28, 2008
Carrier ductless condensation leak
look at the base of the pan where the hose meets the pan for blockage to the drain
Aug 27, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Aug 14, 2012 | Heating & Cooling
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
How do I check the Freon level? Also the furnace has water pooling at the bottom and water running down the side panels, is this from condensation or a larger problem?
Hello, in order to check freon level you will need a set of gauges. The water at the bottum is aresult of a cracked or rusted condensate pan or a clogged condensate drain, try using a shop vac to clean any sludge in the condensate line.
Jul 26, 2011 | Weather King 10AJA3001AH Air Conditioner
Coil is leaking. need to clean it out but don't know how? it's supposed to be easy. can you tell me what to do?
If the cooling coils are leaking, you'll need to do more than just clean it, You need to replace them, as you're loosing refrigerant gas. Or is it simply a case that they are sweating? If that's the case, the condensation should drip into the condensation pan and drain outside via the drain hole in the rear of the condensation/drip pan.
Cleaning the coils is a good idea. But, it will involve sliding the inner mechanical portion of the unit out of the outer shell of the cabinet. If you decide to do this, have a helper handy for it's removal.
Hope this has helped you and thanks for choosing FixYa.
Jul 25, 2011 | Haier Mechanical Air Conditioner HWF05XC7
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
Dripping from underneath the engine
Dripping condensation from a/c evaporator core is normal. If it wasn't driping from there it would be all over the passenger side floor. While it's dripping, find where the drip is coming from on the firewall and remember where the drain hose is...They often plug up and knowing where it is will help you if it does.
Jun 21, 2009 | 2005 Audi A3
Condensate Drain
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Weather King 12AJA6001AH Air Conditioner
Condensation from the coils
check drain hose maybe is obstruct or have bad plunk.
Feb 12, 2009 | Sanyo 09KS51 Mini Split Air Conditioner
Collecting water on top of house boat from air conditioner
Thess units are designed to discharge the condensed water onto the roof under normal conditions. HOWEVER you should be able to have a sheet metal person make up a drain pan to fit under the unit.
You would ten need to add an additional gasket between the drain pan to roof and drain pan to A/C unit. The drain pan could have a hose connection attached to the drain pan. Try it, you might like it.
Also you may have to get longer screws to tighten down the A/C from below.
Jul 22, 2008 | Dometic Rooftop RV Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
256 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
