Question about E-Machines eMachines Desktop PC
Emachines desktop The emachines logo page which used to flash for about 10 seconds on bootup now is onscreen for 60-90 seconds and you have to wait while the hard drive is in idle. Startup is a pain. Is there any way to resolve the issue?
  • DocAndy Jul 18, 2008
    After a lot of detective work, I now understand the problem. I had to get rid of the E machines screen so I could see what was loading behind it on start up. Turns out, everything was loading really well until it got to the USB devices. Then it hung up on device # 1 for the 90 seconds. Turns out that #1 is a multi-port, electrically-driven D-Link USB device. When I unplug it, it loads in about 10 seconds and you barely have time to read the screen. Device # 2 is the printer so I think what happened is that when I added the new printer, the USB multi-port became #1 and hung the system. I think it is looking to see if it has to boot off a device in the USB port. I know there has to be a switch to disable automatic booting off a USB device but I have no idea where to find it. At least we didn't have to reformat the drive and reload Windows XP. Thank you all for your help.
  • 106 Answers
Try re-seating your IDE cables incase if they're loose and the bios is attempting to locate a device that it can't contact properly. You could try and get into your bios and set all IDE devices to AUTO as opposed to the specific device entries shown.
You could try to restore default bios settings via the bios.. I've seen this step solve a few problems in the past - sometimes.
If you haven't made any changes to the hardware (adding a drive, cdrom ..) then I wouldn't worry about the master/slave/cable select setting. But if you did, (take note of existing jumper settings) and try and keep your devices on cable select. If it fails, try setting the end of the IDE cable device to Master and the one in the middle on Slave. Some boards prefer some settings over others. If you're still running into the same issue, then make sure the HDD is the only one connected to the IDE Cable and disconnect the second one.
Good luck
Posted on Jun 15, 2008
  • 99 Answers
Could be a sign of hard drive trouble or may need to reload the Operating System. Back up your data and do a system recovery with the cds the machine came with. That will erase hard drive and reload Windows. If still takes a long time to load chances are it is a hard drive starting to fail.
Hope this helps!
Posted on Jun 11, 2008
Power Switch comes on but moniter goes back to sleep.
use external monitor to setup internal monitor setings
Nov 10, 2012 | eMachines T3508 PC Desktop
ET183105 PC Desktop black screen on bootup
do you get any beeps or ... you know what, describe what happens exactly.
May 19, 2012 | eMachines ET183105 PC Desktop
Cant restore acer netbook back to facotry settings did not do backup when purchased
Recovery procedure for Acer netbooks.
Important Information
The Recovery disc will help you to restore the hard drive with the original software content that was installed when you purchased your notebook. Follow the steps below to rebuild your hard drive. Your drive will be reformatted and all data will be erased. It is important to back up all data files before you use this option.
Restoration procedure:
1. Press the power button to turn the system on.
2. Select to boot from a USB optical drive. There are two ways to do this:
2.1. Press <F2> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup) to enter BIOS Setup.
2.1.1. Select the Boot menu.
2.1.2. Refer to onscreen instructions to set the first device to any bootable optical disc drive.
2.2. Press <F12> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup), and select the USB ODD from the list that appears.
3. Ensure the Recovery disc is in an external (USB) optical disc drive, and exit the boot selection menu, by selecting Exit Saving Changes from the Exit menu or pressing <F10>, or by pressing <Enter> as appropriate.
4. Select Exit Saving Changes from the Exit menu or press <F10>.
5. Follow the onscreen instructions to complete the installation process.
6. When you finish the recovery process, please remove the Recovery disc and insert the System disc again.
7. Restart your computer.
Create a Recovery USB device
You will need a second computer with an ODD to complete this procedure.
1) Insert the Recovery CD into the optical drive. Plug in a USB/flash drive with a minimum capacity of 1 GB.
2) Enter the BIOS setup and set the first boot device to the ODD. Save the changes and exit.
3) Allow your computer to boot up.
4) From the list of options, select "install2usb".
5) You will see a list of available disks, select the USB drive you plugged in.
6) Click the next button to complete the procedure.
7) Remove the USB ODD and USB/flash drive. You now have the Recovery system stored in your USB/flash drive, for future use if necessary.
Apr 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
Emachines W3052 Gets stuck on logo screen when starting up.
My computer does a similar thing, the issue with mine is the mother board which requires everything to be at a certain temperature. Let it run on the start screen for a couple minutes and hit the reset button. If it doesn't boot up you're going to have to get more involved with your PC. Turn off the power, unplug the cord from your power supply, open the case, look for the battery and the JP8 (CLRTC) jumper. Move the jumper from pins 1-2 over to 2-3, wait 30 seconds, and move the jumper back. Close the case, plug in the power cord, turn on your machine, and boot it up. If it still fails to boot check that all cables are securely attached (inside and out), check that the RAM is securely seated, and check the CMOS battery to be sure it is not dead. Beyond this you're looking at a component failure and should contact a repair tech.
P.S. if you feel up to it and can't wait for service, pull the hard drive out of the first computer and use it in a different computer. Be sure to unplug the hard drive from the second computer.
May 16, 2009 | E-Machines W3052 PC Desktop
Tried to do a restore with restore disc that came with the comput
There seems to be a problem with the operating system that is being installed. This often happens if you use the restore disks that came from another computer.
Are you sure that you used the disks that came with that exact computer? Does it flash a blue screen right before restarting the cycle?
Try the restore over again and if the problem persists, you may have to either order new restore disks for your computer or buy a fresh copy of Windows XP.
Apr 11, 2009 | eMachines T3604 PC Desktop
Can not find restore disk
Did this problem just happen out of the blue? Were you using it and suddenly the PC just up and went belly-up? If so, it sounds like you may have bigger problems than merely a Windows problem. If you don't even see the eMachines logo at bootup before the Windows logo, then something more serious, like a motherboard issue, is your problem. Post back with more specifics, but if you don't see anything at all at booting, like any text or logo or anything, then at the very least the integrated ATI video isn't working. The solution then is either get it fixed with a new motherboard or buy a new one. As this particular model is >1 year old, it won't be under warranty, hence more expensive than it's worth.
On the other hand, did you make any hardware changes that you didn't mention? If so, post back with details.
Jan 04, 2009 | E-Machines T5082 PC Desktop
I cannot find my recovery /reinstallation disc for emachine 5260
DO NOT click on that Format option. It will wipe the entire recovery partition.
First look at all your programs to see if there is a recovery program. (Not System Restore.) It would probably be located in Start>All Programs>Accessories>System Tools.
If you do not see one, do a Restart on the computer and watch for a brief message as it begins to boot up. It may say something like "Press Delete for Setup. Press F10 for Recovery." It could be any "F" key, but you only have a few seconds to select it. If you miss the first time just wait and reboot again.
Normally you will have the option to do a full recovery (Everything wiped and restored as if you just purchased it.) or a selective recovery which will save your documents. If you don't have important files or if you can back them up on a flash drive, it would be better to do a full recovery.
Comment back if you are still having trouble.
Dec 10, 2008 | E-Machines eMachines Desktop PC
System issues
you can uninstall the printer and check for the problem
Jun 11, 2008 | E-Machines eMachines Desktop PC
T6410 delay in booting.
Which program do you have booting on start up. Do have Nortons, or any other AntiVirus, Firewall or Spyware softare installed> when did this problem start? Did you make any changes to your hardware...uninstall any important .dll files?
Feb 23, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
43 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
