Question about Samsung DVD-VR357
My recorded disks will not play on any other players
I record movies from my DVR. They all play well on my machine, but will not play on anything else (even a computer. I read the other post and solution that said that finalizing the disk should take care of the problem. It doesn't on mine. We went out and purchase the same DVD-VR357 for my daughter. It would play the R+ DVDs, but not R- DVDs. So some will not even play on the same system. What am I doing wrong? I am finalizing all of them.
Help?
  • larrynpn Jun 23, 2008
    I'm having the exact same problem.
    The problem here is the Disk is not finalizing when using DVD-RW. When I finish copying from VHS to DVD using DVD-R dics, the machine will ask if I want to finalize. I press “yes” and the machine will finalize the disc. When it finishes, it displays the menu to be used with the disk on the TV screen. I can play the newly made disc in any DVD player.
    But when I use DVD-RW disc, and press finalize, I get nothing but a black screen!
    It will play in the Samsung DVD-VR357, but it will not play in any other DVD player.
    I think it might be because I do the editing on the DVD-RW and not the DVD-R.
    The only solution I came up with this is this.
    Since the newly edited disk can be played in the DVD-VR357, play it and copy the DVD+RW to VHS tape and then copy the VHS tape to DVD-R. That way you can play your edited material in any DVD player. But then you run a risk of losing picture quality doing this copying and re-copying. I am not totally satisfied with this SAMSUNG DVD-VR357.
I finally took my Samsung back to Sam's Club and traded it in for a JVC.  Warning to all...I could not burn any DVD's from my DVR.  For those who don't know what a DVR is, it's the same as TIVO, only it's the Direct TV version of it.  The JVC keep giving me a copy right notation.  But, you can copy it to the VHS recorder.  So, I thought, ok...I will copy it to a DVD from the VHS tape.  It won't do that either.  It is becoming difficult to even obtain a DVD/VHS recorder now.  At least with the Samsung you could copy to a DVD disk and play it back on the Samsung.  That's great until the Samsung breaks down.  I guess our options are becoming very limited.  I wonder if we will soon be able to just upgrade more memory into our TIVO or DVR?  It would be far less expensive and give you a higher quality to view than having everything on VHS.
Posted on Aug 23, 2008
  • Samsung Master
  • 2,794 Answers
I've heard of DVD players having trouble reading RW formats if there not being played from the player they were created in. The best thing you can do is check the manual on the DVD you are playing to can read that particular format of DVD.
I've been doing this for serveral years now and I find that most DVD players out there don't have a problem reading DVD-R disks. Fortunately I have set all the burners and recorders to use that one format and playback hasn't been a problem unless the DVD player was created before DVD burning was around.
Make sure you finalize them when your done.
The best thing to do is to get a few DVDs of each format, record on them, and see what works best for your needs. It will take some experimenting at first but it will save you a lot of trouble in the long run.
Good luck
Posted on Jun 23, 2008
PIECE-O-****--
Posted on Jun 16, 2008
  • RUDYBO Aug 23, 2008
    BIGGEST PIECE OF JUNK I EVER OWNED--WILL NOT EVEN PLAY THEIR CD FIRMWARE UPGRADE DISK--
    WILL NOT PLAY +RW/-RW DISKS
    BEEN USING LITE-ON/POLAROID/INSIGNIA DVD PLAYERS-BURNERS FOR THE PAST 3 YRS & HAD NO PROBLEMS LIKE THIS--
    SAMSUNG HAS SOLD THEIR LAST VIDEO DEVICE TO ME--
    SOFTWARE SUPPORT IS USELESS--
    LOOKS LIKE I`M STUCK WITH IT IN SOUTH LOUSIANA!!!
SOURCE:
I have recordered many home movies to a dvd+r
Dvd+r disks are the least compatible to most devices.
Try using Dvd-r instead.
Dec 02, 2009 | LG RH1999H DVD Recorder/HDD Recorder
How to connect dvd recorder to tv????help
if youre going to be recording programs from the TV , it cant be , normally TV s have A/V
inputs and NOT outputs , the only way is to connect it thru a VCR A/V outputs , hope it helps , AJ
Jul 12, 2009 | Cyberhome DVR 1600 DVD Recorder
Want to burn some movies off my dvr
http://www.usersmanualguide.com/
see if theres a manual here
Apr 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Can't record anything....dvr won't recognize blank
Not sure, but could be as simple as switching to a dvd-rw disc. Not all recorders recognize all formats.
Mar 16, 2009 | Televison & Video
Recorded dvd's won't play in another dvr
The problem is not the dvds themselfs it is the other play that you are trying to play them in (some players do not play DVD- and DVD+ or any other of self recorded disks) Look on the players box to see all what types of disks it can play!
Please rate answer and help keep this site free
Jan 03, 2009 | Zenith XBR716
Toshiba dvr will load some dvds & not others
My machine has also done this since it was new. I was just about to bring it in for repair when I thought I would try one more thing. I turned on the recorder. I put in the movie that would not play and let it load (of course it would not load). I pushed the on/off button on the recorder and held it down until the "wait" message came up on the display. After the message disappeared I turned the recorder back on. To my surprise the movie loaded and played. I tried all the other movies I had trouble with and they also played. I hope this helps. I saved my self over 200 dollars in repair bills. I was quite surprised at the lack of help from toshiba.
Dec 06, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Movie regions
Go to: www.videohelp.com what you are looking for is a region free hack..put your machines numbers in, hit search, scroll down, look to right of screen to see if a hack is listed.
Jun 26, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Can't record from my digital cable tv to my sylvania dvd/vcr ..........
Depending on the unit your going to need to check the back of the DVR for video out ports... My DVR has VID/HDMI/VCR/1394/SaTa and IR ports I use the VCR out to record with... because on my DVR I can say "Play this movie... now record to VCR and it will only play the movie on those VCR ports not on my TV so all I gotta do is hit record on my VCR... As long as you have audio/video jacks on the VCR. Then even some have it blocked so you can't do that... depends on model. So try recording on the VCR using the video ports instead of the COAX cable.
May 05, 2008 | Televison & Video
Samsung DVD-VR357 Logo
288 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
