Question about Sony Handycam DCR-HC40E Mini DV Digital Camcorder
Hi, When I try to play my SONY DCR-hc40e handycam in play/edit mode, the LCD shows the play-edit mode for a second, then immediately says "usb mode" "disconnect usb cable before changing the setting". whereas I havent connected any USB cable. I showed this case to Sony service center in Bangalore(India),they told me that they have checked the set. The set is fine.Probably the bcoz of the battery it is happening. But then problem remained the same,I went to a SONY shop,and tried with a new battery. Any solution.
SOURCE:
SOURCE: Sony Handycam DCR-HC40E
Sony Handycam DCR-HC40E DONT RUN UNDER WINDOWS VISTA?
Posted on Feb 12, 2008
SOURCE: Sony Handicam DCR-HC40E not getting recognised by Vista
PLEASE DCR 40 E DRIVER
Posted on Mar 15, 2008
SOURCE: SONY HANDYCAM DCR HC19E PICTURE PACKAGE 1.5 FREE DOWNLOAD & MOVIE EDITING SOFTWARE
i need the vista software
Posted on Aug 13, 2008
  • 4234 Answers
SOURCE: HANDY CAM LCD SCREEN BLANK
Inside the door hinge area is a small switch that normally would turn off the viewfinder and turn on the LCD panel. THat switch could be defective or mechanically not being switched. WIthout opening up the unit, I can not tell specifically. This shouldbe a simple repair for any shop that repairs cameras.
Dan
Posted on Oct 07, 2008
ripleymojica
  • 643 Answers
SOURCE: WINDOWS MOVIE MAKER NOT DETECTING MY SONY HANDYCAM DCR-HC 15E
esupport.sony.com get updated driver software.
Posted on Jun 03, 2009
My Sony DCR-HC40E has a fault with the touch screen. The touch screen is not displayed so I am unable to play/edit or even record/view anything. The screen is usable if you know where the controls are...
Hi!
The flat LCD cable which goes through the hinges has broken - a common problem with many Sony camcorders. You will have to give it to Sony for repair.
I work for Sony.
Tom
Oct 09, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
DCR-HC40E SONY CAMERA DRIVER FOR WIN VISTA
I've just bought a new computer for video editing, I'm aware that this model DCR-HC40E does not run under vista. Question is, is there a driver that actually be able to drive this?
If so please link me the site. Or is there any other solution.
Your Help is very much appreciated.
Thank-you.
Jun 28, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony dcr hc30
I wish to transfer my DCR-TRV480 NTSC video to my PC. I have set my camera to Play/Edit mode. However, when I insert my USB cable into my video camera, the message "Disconnect the USB cable before changing the setting" appears, preventing me from playing/transfering my video. What can I do?
Apr 11, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Hello
I found a solution installing the generic Sony USB driver in Vista Ultimate using compatibility mode (Windows XP SP2).
Mar 12, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
Oct 02, 2007 | Sony Handycam DCR-TRV265E Digital...
Sony Handycam DCR-HC40E Mini DV Digital Camcorder Logo
48 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
