Question about Sharp Notevision XG-NV6XU Multimedia Projector
Sharp xg-nv6xu projector
Large green circle in center,Bad panel?
  • 3 Answers
Posted on Feb 24, 2009
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Missing blue region
It sounds like the bulb overheated at some point. Time to replace the bulb.
Oct 31, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Yellow in center of picture
The blue device is dying allowing green to shine thru instead of white. Very common problem called color decay. Happens on average about evey3-4000 hours. I suggest next purchase a dlp product, they are immune to this problem. Good luck
Mar 29, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Works but prdominantly green, can't ajust with color controls
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
Mar 07, 2009 | Sharp Notevision XG-NV6XU Multimedia...
I have a sharp xg-nv5xb projector that wont power on.
bad power board or blown fuse. If you feel comfortable you can take the out case off and follow the power connector to the board. You can then check the fuse. Make sure the unit is unplugged before doing so. If the fuse is fine then you will need to replace the board as it probably has a bad capacitor or resistor. You can find a power board online but to be honest, its probably not worth the money to by a new one. Would probably be cheaper to buy a used one with a bad lamp and cannibalize the power board out of it.
Mar 06, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sep 05, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Green or Yellow Spot on screen
It could be a dirty filter or dust in the intake holes. Vacuum (preferably) or blow out the vent holes. The projector may be overheating because of this.
Oct 24, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp Notevision 6 XG-NV6xU
reset the lamp hours on your projector
Jul 28, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp Notevision XG-NV6XU Multimedia Projector Logo
165 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
